0 Members and 424 Guests are viewing this topic.
Void
Quote from: T-1000 on October 27, 2014, 07:23:46 AM
The "Leedskalnin PMH" was my comment and the winding direction is always beginning from same end which means 1 layer until end then 1 turn to beginning and next layer on top from same end as first layer...
Hi T-1000. Ok, from what I recall I don't think that Leedskalnin mentioned using one turn to go back to
the starting point and then continue winding from there, but it shouldn't really matter much. If you continue
winding in the same direction back and forth from one end to the other end it should work out to about
the same thing as far as coil performance, but it will only make a difference which end the wire end is
on after each two layers.
All the best...
T-1000
Quote from: Void on October 27, 2014, 07:29:35 AM
It matters a lot. :)
When winding electromagnet on conventional method each layer North/South is facing second layer South/North which effectively lower magnetic field strength outside of the coil. The strongest magnetic field is inside of coil.
When each layer North/South is facing second layer North/South you get same effect as two magnets forced with same poles. This results magnetic field concentrated on center outside of coil and is strongest there. This is same effect as optic lenses are doing...
P.S> The most logic reason why we want to have strongest magnetic field on scalar grenade coil 1/4 and 1/2 halves is what makes electricity - the magnetic field from inductor and the electric field from antenna leading from Tesla coil.. Like vice versa when we have electric field and magnetic field on the wire when there is current.
MenofFather
Quote from: Void on October 27, 2014, 06:40:53 AM
Hi MenofFather. T-1000 translated that Ruslan said this coil is wound like Leedskalnin's PMH coils.
If that is correct then you wind the first layer of the coil from one end to the other end, then
continue winding from that end back towards the first end, and still winding in the same direction. Just like
the first two layers of the grenade are wound for example.
All the best...
That not corect. And that is not bifilar. And that is not that, that say Ruslan.
MenofFather
Quote from: Void on October 27, 2014, 07:18:12 AM
Hi John. You have completely missed the point on both topics being discussed above. ;)
There was no questions raised about how to wind the grenade coil above.
Yes, there are also different translations of Ruslan's tesla coil frequencies being both 1.5 MHz to 1.6 MHz,
and 1.8 MHz being posted here as well.   ;D
All the best...
Ruslan first say, that in 24 V system kacher frenquency is 1.8 megaherc, but latter in coment say, that he made mistake and Tesla coil frenquency is 1.6 megaherc.
John.K1
Void,
Did I missed a point??? and what about that discussions above with the picture of some wires coming out of tube and discussion of winding techniques and some lengths... :)
Anyhow, I just messing with the katcher and the frequencies are allover the places. I move a little bit primary and get different readings. I use my multimeter  to read radio frequency. I know, Ruslan has said the primary coil should have diameter 2- 2.5 of secondary. But If I have my primary in such distance I get almost nothing on my primary. It is not strong to lit my fluorescent lamp nearby even with 24 V.
Any hint here?
