0 Members and 145 Guests are viewing this topic.
Void
Quote from: Hoppy on October 27, 2014, 12:50:49 PM
Does anyone have a clear idea how Ruslan wound his bifilar coil. Is it wind first layer, then return to start for second layer or a conventional front-to-back and then back-to-front? Also, is it wound opposite to antenna (CCW from thin end of grenade)?
Hi Hoppy. It was stated here today by MenofFather and T-1000 that for the 'bifilar inductor'
you wind one layer and then wind one long turn to return back to the starting point, and
then wind the next layer, etc.. All turns wound in the same direction, which is opposite to
the winding direction of layers 1 & 2 below on the grenade coil. Specified length from Ruslan
was translated as half the length of the grenade coil, which is 18.75m.
All the best...
Hoppy
Quote from: Void on October 27, 2014, 01:21:08 PM
All the best...
Thanks Void, this is how I understood it from previous posts but wanted to double check with the rest of you. I assume then that at 18.75m, we may have more than two layers.
Hoppy
Quote from: MenofFather on October 27, 2014, 01:18:15 PM
First woud one layer normal, then isolate and go to start, then again isolate and wound in same direction second layer. Begining of inductor is in oposite direction, than multilayer coil begining, but here is not wery important or in oposite or not direction.
Thanks MenoFather. What do you mean by 'isolate'?
Void
Quote from: Hoppy on October 27, 2014, 01:27:51 PM
I think Itsu said 18.75m will work out to three layers, if I understood him correctly. :)
It will depend on your exact wire gauge of course. Not sure, but I think 2.5mm^2 is what Itsu used.
Maybe Itsu can confirm the wire gauge.
All the best...
Enjoykin
Quote from: Hoppy on October 27, 2014, 01:11:43 PM
Thanks Enjoykin. Is the length 18.75m, half the grenade length?
Should be.  :)
Somebody can make grenade for example 150m - and those 150 will be 1/4 of 600 meters.
Main question here is ??  how estimete best Earth-frequency (Telluric-frequency) and match it with our frequencies to extract power from Earth-currents. Tesla secret is those Earth-currents multiply yourselves making Standing Scalar Waves (node currents) through the whole entire planetary globe - which again had been confirmed many times by Great Nikola Tesla.  :)
