0 Members and 56 Guests are viewing this topic.
John.K1
Enjoyking, now you make me lough.  Kak ja mogu znat ty Rus:) :) :)   Sejcas ja ponjal i poznal :D
It is conversation of Ruslan with others of your brothers and they speak about - Kak etu stucku nastroit :D :D
Enjoykin
Quote from: John.K1 on October 27, 2014, 05:21:27 PM
OK John  :D
Have you DSO in your laboratory. If you have do exactly like Akula and itsu has done. Scan Ground to find Telluric response. :D On that frequency tune your Katcher secondary without bifilar-choke and antenna connected. Reference oscillograms are from Ruslan Katcher video tunning. Only sharp unipolar impulses on collector of your 2sc5200 transistor.  Also tune your 1/4  Grenade to resonate on same frequency (number of windings or wire lenght). We need here1/4 wave resonace with shortening factor of copper wire. I wish you success
Reg.
@Itsu
Itsu did that new spectrogram was with free end coil or free end was grounded. Resonant peaks are from coil or grounded coil ??
Reg.
itsu
Quote from: Enjoykin on October 27, 2014, 05:43:40 PM
@Itsu
Reg.
Enjoykin,
its only connected to the scope probe (see video).
But the groundclip of this probe is grounded through the scope, so yes these 2 screenshots are taken with one side grounded.
When i attach my special ground lead (connected to the same ground of the house) also to this same point, then no change is seen.
Regards itsu
Enjoykin
Thanks Itsu  :D
I suspect on small Peak-Peak amplitude at your RF generator output and also maybe high DC resistance and self-inductance of your Grounding (including ground conductor). I think Akula has done experiment with maximum amolitude of his signal generator. He used lot of Litz wire for grounding. When he used solid copper wire than groud frequency response went up. If you have old analog RF generator up to 5MHz try with him. Maybe will work to get proper response. I think up to 2MHz willbe enough to find response. It is as we have seen in Akula and Ruslan between 1MHz - 2MHz.
I have idea. Why don't scan your ground without any coil - just sweep your special ground wire. Maybe you will find something ??
On same way you can scan ground of your oscilloscope (self-scan) and other equipment.  :)
Reg.
magpwr
Quote from: Enjoykin on October 27, 2014, 03:55:01 PM
Watch Akulas video how tuning Tesla coil to Telluric frequency !!
РОМАН КАРНОУХОВ УСТАНОВКА №2  7 сент. 2014 г.
https://www.youtube.com/watch?v=-rALEpvBQig
AKULA TIPS and TRICKS
1. Find Free resoance of your coil. Free end in air. Search for maximum amplitude on your coil. His 1.0083MHz
2. Connect Working ground on Free end and search for Resonance - Maximum Peak Amplitude. His 4.88MHz. Use Separate Ground for coil. Another ground for Oscilloscope, Spectral Analyser and Signal Generator.
3. Search lower common multiple of Ground Resonance 4.88MHz. There are many. His is 1.842MHz. Amlitude is lower and very hard detect - because there are many common multiples (Earth harmonics) in signal. Resonance is very-very sharp. Need carefully and slowly mannual sweep. Once you change Ground conductor lenght - everything you have found will be changed. Search again for new ground lenght.
4. On that resonant frequency of Ground response 1.842MHz make working TT (Tesla Transformer or Katcher) without connected bifilar-choke or antenna.
hi Enjoykin,
Well Done Enjoykin.I am impressed now. :)
Everyone whom just came to the forum this was the video which i was interested in previously and MenofFather have assisted me to type out  Akula speech into Russian base on this video below.
It is this video and assistance of MenofFather i have complied a pdf previously in Russian and in English below.
I used google translate to translate Russian to English (section by section as google translate do have certain limitation on the words it can translate at any one time)
I was asking for anyone around 1 month back if someone can get this document professionally translated to English since google Russian to English  translation is not perfect.
I have attached this pdf in Russian and English of Akula speech.
Hopefully more sentence can be decoded.
This is the video which allow me to get interested in Akula and Ruslan device
Regarding Harmonics
This is the video produced by Akula but now was deleted.This translated video of Wesley of Akula video showing us on how to get this waveform which is related to 30th and 60th Harmonics as i discovered weeks back.
Take a look at the waveform which i previously attached to show the alignment between 2 frequency 60th harmonics apart and take a look at this older video which was based on 30th Harmonics.
Akula video #5  translated by Wesley. ( Free Energy device)
http://www.youtube.com/watch?v=PPHipGkfSAY&list=UU1ZrGlkxBvG9WOwIs2eApLA
Wesley: Translation of  video#4 of Akula
http://www.youtube.com/watch?v=ScXhI2hQawc&list=UU1ZrGlkxBvG9WOwIs2eApLA
