0 Members and 550 Guests are viewing this topic.
John.K1
Thanks MenofFather. If you know, can you tell me please what is that small coil- couple turns in opposite direction, right behind the Tesla for? I am not talking about the coil on the ferite rod.
Thank you.
MenofFather
Quote from: John.K1 on October 28, 2014, 03:40:46 PM
Thank you.
I not understand. "A" is antena in by me posted schematic.
John.K1
Meno,  It is not in your schematic. But if you watch one of his videos, he has on the tube - Tesla , after there are some turns in opposite direction (he clearly state that, also small gap between tesla and this coil) and then, this is connected to the coils on ferrite bar.  I didn't find more info about this anywhere.   His opposite coil is under the red tape.
Thanks.
itsu
Quote from: Enjoykin on October 28, 2014, 09:24:25 AM
HI
Most important thing in Ruslan device are MOUSTACHES :D This device will work only when both MOUSTACHES ARE IN PHASE. Find way to grow up these SPECIAL BIG MOUSTACHES and phase it with small MOUSTACHES :D
Oscilloscope probes are on BIG MOUSTACHES (before diode bridge) and SMALL MOUSTACHES (current resistor at end of Grenade coil). Rectified voltage on 1uF capacitor is 800V
Ruslan is experimenting every day to get more than 5KW power.
Hmmm, more confusion, what do you mean by "before diode bridge" as in the drawing from MenofFather?
And "Rectified voltage on 1uF capacitor is 800V". What 1uF capacitor? There is none.
And 800V!?  The scope shows 10V/division, so i can see max. 100V.
I have tried to measure these points, but the signals seen are in no way compareable with what i see in those scope screenshots.
Yellow is between diode bridge and choke, negative 60V (same is in MenofFathers diagram red spot)
Green is my current probe (set at 500mA/div) at the exit lead from the grenade coil to 10uF cap/bulbs/ground.
Regards Itsu
Enjoykin
Quote from: itsu on October 28, 2014, 04:34:50 PM
Yellow is between diode bridge and choke, negative 60V (same is in MenofFathers diagram red spot) Green is my current probe (set at 500mA/div) at the exit lead from the grenade coil to 10uF cap/bulbs/ground.
Regards Itsu
Hi Itsu
No need for confusion Itsu. MOUSTACHES are Ruslan's term.  :D
Ruslan has measured BIG MOUSTACHES voltage at bifilar coil (inductor). One end of bifilar was grounded. SMALL MOUSTACHES are current signal at current transformer from grenade. He said he was measured voltage on two capacitors 2x0.47uf = 1uf and it was more than 800V rectified. Signals are not comparable with yours because your setup is wrong. Load is not connected because Ruslan made experiments with phase shifts in circuit. And that Brutto schamatic is not correct. Need to be deleted !!
Frequencies of BIG MOUSTACHES (voltage) and SMALL MOUSTACHES (current) are CORRECT - as on pic above.
Reg.
