0 Members and 50 Guests are viewing this topic.
itsu
I tried to find the most logical points on where the latest Ruslan scope shots could have been taken and came up with:
current trace (spiky signal / little moustache) in the main grenade lead to 10uF cap/bulbs/ground (but i only see one peak positive; how come?)
voltage trace (Big moustache from Kacher) on the main grenade between this grenade and the 28 turn yoke secondary
This way we can measure the voltage and the current through 1 coil (main grenade) and see if they align, (meaning in resonance).
First screenshot is without Kacher activated,
second screenshot with Kacher activated.
Video here (where you can also see how i wound my Kacher secondary / choke / antenna):
https://www.youtube.com/watch?v=PMAkYEv2ttI&feature=youtu.be
I tried to find a similar positive/negative spiky signal with my current probe probing on severall places, but none was found!
It seems i made a mistake on the ferrite choke inbetween the Kacher and the antenna, both 5 turns were in the same direction (CCW),
so i changed that afterwards, but no changes in the above signals where seen.
My Kacher secondary - choke - antenna is now like this:
Kacher secondary 0.6mm wire on 5cm tube 9cm long CW, then 4 turns 4mm wide copper tape CCW.
Ferrite choke 5 turns CW -> 5 turns CCW.
Antenna 5 turns CW
It resonates at 1.760MHz
Regards Itsu
itsu
Quote from: Enjoykin on October 28, 2014, 06:05:59 PM
Hi
No need for confusion Itsu. MOUSTACHES are Ruslan's term.  :D
Ruslan has measured BIG MOUSTACHES voltage at bifilar coil (inductor). One end of bifilar was grounded. SMALL MOUSTACHES are current signal from current transformer from grenade. He said he was measured voltage on two capacitors 2x0.47uf = 1uf and it was more than 800V rectified.
Signals are not comparable with yours because your setup is wrong.
And that Brutto schamatic is not correct. Need to be deleted !!
Reg.
My setup is wrong? Now you tell me   ;D
What is wrong then if i may ask?
Regards itsu
Enjoykin
Did you measured little moustashes (current) with current transformer or maybe with resistor ?
Did you wound your bifilar like Tesla setup or Hooper setup. There is big difference between !!
Lenght of bifilar 18,75m (half of grenade).
This is important - Your second oscillogram at 22.18.43 is very important and very similar to Ruslan.
Watch his video again from 1.04 and compare yourself. He has on top of positive and negative peaks small humps. It means you have significant phase error in your setup.
Picture for compose one's thoughts. :)
magpwr
Quote from: MenofFather on October 28, 2014, 02:41:52 PM
Were pulses can be, were Ruslan looking in video. On red big dots Ruslan can be puting ends of oscilioscope, here is pulses.
hi MenofFATHER,
It's early morning here.Before i run off for work.There is not much time.
The circuit diagram you have presented is 100% wrong.
This is easy for me to explain.The "voltage drop" across STTH12R06 diode surely cannot be higher than "2volts" even under load.
Please just take a look it's it's datasheet and look at the voltage drop.
Then full bridge rectifier which is consist of 4 diodes assume each diode got a voltage drop of 0.7volts .
In simple words there is nothing useful to be obtain from the full-bridge rectifier except to monitor "frequency" only.This would appear as 2 times ripples of actual frequency. :D
Ruslan have never present a full circuit diagram of his device to date.The block diagram is not useful in this case.
Only Akula have released various circuit diagrams.
Enjoykin
Itsu check phasing at your push-pull ferrite. Both branches with 3 turns and 28 turns.
First change phase on 3 turns coil then on 28 turns and than both.  Reference is Ruslan small moustaches oscillogram. If you can't get look similar like at Ruslan's oscilloscope - change phasing of your bifilar coil. One end should be grounded - that which is connected on resonant capacitor.
We don't know here how Ruslan has wounded his Bifilar coil (inductor) - like Tesla setup ot Hooper setup.
Analyse slope of Ruslan's small moustaches (current). Whqat can you see ?? Yes, very sharp rise and fall times - sharp eadges means very short current impulses did it. It means short time constant - probably 3 turns coil or something similar with short time constant.
