0 Members and 226 Guests are viewing this topic.
Enjoykin
Quote from: John.K1 on October 28, 2014, 07:44:21 PM
Can anybody give me some info about that small coil right behind the Tesla coil?. It is some turns OPPOSITE to Tesla . It is under the red tape.    (7:13 ,   https://www.youtube.com/watch?v=KN-ZmCW0W8w  ) ??
Cheers
Hello John.K1
Yes Akula and Roman can give you all info about generator. !! :)
That small red tape coil was wounded in opposite direction from Katcher secondary. Lenght of secondary is 9 cm, magnet wire 0.8 mm diameter. I think next was wounded cooper strip about 3-4cm in lenght and end going to bifilar-choke.
What is iteresting Ruslan use 1/2 wave to superpose Big Moustaches (voltage) with Small Moustaches (current). He has called it Resonance in Resonance. That all for now !!  :D
Reg.
Enjoykin
Quote from: magpwr on October 28, 2014, 06:50:44 PM
hi Enjoykin,
I may like Brutto drawing of the circuit diagram as you have shown us.
But Brutto have not produced any working device yet.
People are still using 1/4 and 1/8 resonance for this device.I think they are mixing up this with Don Smith device which is base on 1/4 wave. :D
Why isn't there anyone else besides me whom realized for Akula video it's all about the Harmonics or Sub-harmonics.30th Harmonics and 60th Harmonics for new device.
In order to see perfect frequency alignment only 30th harmonics and 60th harmonics is suitable .2 reasons one is to fit within yoke core capability to around 75khz and another fit within air-core capability not below 18khz as mentioned by Akula.
In the old Akula video tela coil tuning video .The frequency derive from his sprecturm analyser is 165khz and another signal is 55khz .
Use the attached Harmonics calculator it reveal "1650900hz" as 30th harmonics for 55030hz.This is to see prefect frequency alignment besides 60th harmonics.
This is the last time i will be talking about harmonics.
Hello magpwr !!  :)
Why last time ?? I think you are right - everything here is about Complex-Harmonic-Mixing. Akula probably used 30th harmonic with his Tesla transformers - Ruslan used 50th Harmonic as he said in his new video. You can tray mixing of Telluric frequency with highest amplitude response (somwhere from 4-7 MHz) but is extremely difficult to get results as Akula said  - because he has tried it.
When i said  Harmonics or Sub-harmonics i mean not only to fit two main Harmonics but maybe all Harmonics and their all Sub-harmonics. To be sure what;s going on here we need something like Harmonic Spectrum anaylyser - to scan complete phase space from 0Hz up to 1GHz and more.
But Complex-Harmonic-Mixing is not only main stuff. Here is also Present Tesla Radiant which is totaly unknown for us - what he is doing, how and why he is doing like he do !! Tesla Radiant is pretty Big Shark for us - Megalodon Shark !! :D
Ruslan new video
https://www.youtube.com/watch?v=C8RcRlzk16w
Both of them used 1/2 wave lenght for consistent phase mxing. Maybe is there something more what we don't know or have not taken in account.
Reg.
John.K1
Enjoiking. I know that. But what is its purpose? I do not copy length or sizes, I am trying to u derstund how it works.
MenofFather
Quote from: John.K1 on October 28, 2014, 03:56:54 PM
Meno,  It is not in your schematic. But if you watch one of his videos, he has on the tube - Tesla , after there are some turns in opposite direction (he clearly state that, also small gap between tesla and this coil) and then, this is connected to the coils on ferrite bar.  I didn't find more info about this anywhere.   His opposite coil is under the red tape.
Thanks.
That part need to hold ferite road.
From other Planet
Quote from: Enjoykin on October 28, 2014, 07:38:32 PM
My variant of Ruslan device.  :)
Hi Enjoykin, in your drawing the connection of ur inductor coil basically shorts the 3 Turn Coil + tuning cap and the Inductor coil. You maybe made a mistake there?
Concerning grounding, Don Smith used variable caps/resistors to tune his earth, maybe that way one not needs to adjust whole system to local earth, just a thought...
Also i remember Don saying to change conductor diameter/material at the end of the wires, that needs to be certain length.
Attached is one of my versions of the grenade coil of Akulas big device, not sure its the way he meant it, but it has 2 harmonic resonant frequencies.
regards
