0 Members and 169 Guests are viewing this topic.
magpwr
Quote from: Enjoykin on October 28, 2014, 08:32:18 PM
Hello magpwr !!  :)
Why last time ?? I think you are right - everything here is about Complex-Harmonic-Mixing. Akula probably used 30th harmonic with his Tesla transformers - Ruslan used 50th Harmonic as he said in his new video. You can tray mixing of Telluric frequency with highest amplitude response (somwhere from 4-7 MHz) but is extremely difficult to get results as Akula said  - because he has tried it.
When i said  Harmonics or Sub-harmonics i mean not only to fit two main Harmonics but maybe all Harmonics and their all Sub-harmonics. To be sure what;s going on here we need something like Harmonic Spectrum anaylyser - to scan complete phase space from 0Hz up to 1GHz and more.
But Complex-Harmonic-Mixing is not only main stuff. Here is also Present Tesla Radiant which is totaly unknown for us - what he is doing, how and why he is doing like he do !! Tesla Radiant is pretty Big Shark for us - Megalodon Shark !! :D
Ruslan new video
https://www.youtube.com/watch?v=C8RcRlzk16w
Both of them used 1/2 wave lenght for consistent phase mxing. Maybe is there something more what we don't know or have not taken in account.
Reg.
hi Enjoykin,
It's not your fault.I have mentioned about Harmonics before you came to this forum.But other members are getting mixed up with Don smith by using 1/4 or 1/8 wave in the Russian forum.
They are being lead into the wrong direction by following brutto.
I like this coil presentation which you have attached previously.
This way no more stupid question from others related to how to wind a coil if they don't wish to dig for information.
Recall my findings on frequency used to connect to 1.0xuf capacitor in series with 25 turns windings.For my case it was found to be at 14.85khz upper frequency 871khz.
Then these needs to be multiplied by 2.   example : 14.85khz x 2 =29.7khz (Yoke core frequency at 3 turns) and 871khz x 2 = 1.742Mhz (Tesla coil)
This is the only area where 1/2 wave is applicable.
I just received the Russian PIO capacitors 20uf 400volts which was sold as pairs and the KT926 transistor.
For Tesla coil at the top(Nearest to the middle of pvc pipe) just few turns around 5 with spacing with between those windings using the same continuous magnet core will do as well.
The reason for this few turn is to optimize streamers/spark from the top and ensure less wastage from the sides of coil.
itsu
The next 2 screenshots taken from this last Ruslan video clearly shows that the big moustache
signal was taken directly from across the main Grenade coil terminating via a FWBR into 2 capacitor.
Questions:
where is this FWBR with its caps shown in any diagram?
what is the purpose of this FWBR and caps?
Together with the current transformer measuring the current in the main Grenade (does it?), it makes sense
to monitor both voltage across and current through this main Grenade to get them aligned, meaning get this coil in resonance.
Editted:  after looking again at the latest Ruslan video it seems that the current transformer is NOT in the main Grenade
coil, but around the big white lead from in the 3 Turn yoke to the 0.47 (or in new 1.2uF) resonance cap, like it can be seen
in the (original) Mikmur diagram leading back to pin 5 of the TL494.
I did measure there with my current probe, and remember i found a sine wave like current signal there, but will try again tonight.
Regards itsu
magpwr
Quote from: itsu on October 29, 2014, 05:18:56 AM
Questions:
Regards itsu
hi itsu,
I thought no one will ask about it.
Since you mentioned about it .The reason why i merely used only 3 turns for the output for my previous setup without the 28 turns from the yoke\toroid which was previously used merely to be full -bridge rectified and was charging the pulse capacitor.
The new design is tapping from the output(Full bridge rectifier as you attached for the grey capacitor) which is leading back as A/C to the bulb & Power supply unit  for loop back purpose.
A/C voltage meant for bulb/PSU if rectified would produce higher dc voltage for pulsing application as compared to 28 turns which the diameter of the yoke was the constraint.
I have attached 2 photos of interest.
This toroid is where i previously spotted one of the 3 turns wire  from yoke core is going through.
Previously i though it was used for AFC then base on this video i noticed there is no interface wire spotted which is suppose to go back to PWM circuit with boost circuit and TC4420 driver.
This is the likely point to inject nanosecond pulse (low voltage first) which is the next stage of my experiment later. :)
Can be seen clearly for this video the probe is connected to toroid as attached. :)
Hoppy
I still have an issue with the grenade winding directions. If you look at the shot below from Ruslan's latest coil, layers 3,4 & 5,6 are wound CCW as viewed from the RHS of the grenade. This means that layers 1& 2 are wound CW, not CCW as shown on Enjoykin's latest post. Following on, the bifilar coil is wound CCW and antenna is wound CW. The antenna is therefore wound in the same direction as layers 1&2, not opposite as I was led to understand from previous posts. Ruslan's instructional video showing the coil with brown coloured wire is wound CCW - CW - CW but this not how I see his working coil is wound.
Instructional video at: http://www.youtube.com/watch?v=lTwq_EbYy7U&list=UU_zn0cdzv_qfsxQUm4e7R9w
itsu
I have editted my previous post concerning the current transformer position.
Magpwr, i understand the toroid is a simple current transformer to measure the current through this white wire.
Hoppy,  i agree, enjoykin has reversed all directions in his pictures/diagrams compared to what it really is,
but i don't think it really matters
Regards itsu
