0 Members and 1089 Guests are viewing this topic.
GeoFusion
Quote from: NickZ on October 29, 2014, 10:57:29 AM
  Extra energy is "coming" from the ground? And not from the surrounding ambient?  Well, maybe, but I doubt it.
  The planetary Earth Vortex is concentrating the Aether, which is the source of all power, everywhere. Possibly the Earth ground connection (working as a tuned antenna), can also be picking up additional positive current, instead of negative. Yes, No?  OR, HOW can we get any extra energy from a ground source about 1 v?
Doesn't energy always flows from a higher source to the lower, not the other way around.
  I do agree that we should develop devices that work directly with the safe cold magnetic currents, instead of the hot electrical sources.
Hi Nick
Check this Vasmus video out, and he measures Amps coming from ground, and when disconnecting the ground from his device, it shuts down.
Same thing happens with Ruslan's Device and he also demonstrated how he disconnected earth and  device turned off. It's Pure Radiant energy.
As example , In the beginning of the vid you will see Vasmus place the amp clamp on the ground pipe, to see 1.40 ~ 1.56 amps.
at 6:20+ he demonstrates to disconnect ground from device and kills the process.
enjoy
https://www.youtube.com/watch?v=ub71Ea5ppio
NickZ
   Geo:
   How can he tell if the current is coming from the ground, or going to it instead.
I understand that the Vasmus device does not work without the ground. But, the Akula first video device proved that it can run at least at 700watts output, with NO ground connection.
  Also notice that Vasmus is not using a longer than 5 to 6 meter ground connection.  Not anywhere close to what is being recommended as a "tuned earth ground" connection, being used by the Ruslan/Akula devices.
  So...  where's the power really coming from???
This is no small detail... as we need to understand what is really going on.
John.K1
Guys,  If I can I would also spend couple words here about free energy.  One point of view can be-  make a high potential- which is HV (or in other term  - static electricity). And to get it move in to the current we use grounding. In this view you collect charged electrons from the air.  Next point of view  is based on the principle of asymmetric capacitor where you pump free electrons from the ground. Next possibility is to gain energy from copper as T Bearden nicely described , by exiting the wire to the excitation point and then give it tiny kick to move highly charged electrons toward the surface of wire as a current.
My question is , what is the principle of this Akula /Ruslan /Kapanadze device?  If we want to successfully build this device we need to fully understand how it works. Ruslan was talking about Ionization of air around. It means the coil attracts free air electrons. But what that bifilar coil doing then I do not understand.Would ground works here as both as an exciter and low potential to make electrons flow as current? I remember Ruslan pointed on importance to have ground free of other disturbing devices. In other words - output relay on the quality of ground.
Hoppy
Quote from: Enjoykin on October 29, 2014, 09:42:36 AM
Hello all at forum !!
Itsu I have not reversed nothing in pictures/diagrams - compared to what it really is. And winding directions are very important in my understanding of Akula device. :)
Do you see where your dog Itsusable (i guess it is his name ??) look at ?? In which direction ??
His eyes are reference point from Grenade winding directions!!.   :)
I think simple. WhenI winding coil i always wind from me to opposite direction - not from back to front(me). My winding directions are coorect, Only thing i don't know is configuration of bifilar-inductor coil over grenade. But there are only two  possibilities. Tesla way or Hooper way.
Reg.
As Geo has pointed out, the fact is, Ruslan has shown grenade coils wound in totally opposite directions (CCW, CW, CW and CW, CCW, CCW as viewed from the same end), so unless one of them did not function, then we have to assume that both coil configurations are valid.
Hoppy
Quote from: NickZ on October 29, 2014, 11:52:42 AM
   Geo:
Nick,
You may recall that a.king21 was adamant that Kapanadze told his team that his devices could run without an earth connection and that his team witnessed this. As you rightly say, we need to understand what is really going on!  :-\
