0 Members and 91 Guests are viewing this topic.
NickZ
  We would all benefits from knowing where the additional source of power is coming from, on all these self running devices.
  But, as time goes on, it looks more and more (at least to me), that we are tapping ambient energies, from any available surrounding sources. Can be a combination of both positive and negative ambient/ground currents.  This is still all Tesla stuff... which he knew about, and could tap into, and we still can't.
Unless you're Russian. Ha!
NickZ
  Hoppy:
   Yes, both TK and Tesla were able to run some devices with out the earth ground.
Like with the Pierre Arrow car which did not use a long ground connection, to be able run at 90mph. The new expensive Tesla electric cars would really benefit from that, No batteries...
  Dr. Stiffler had also used what he called a "virtual ground", like a short ground wire only about 15 inches long or so, sometimes connected to an aluminum block, or just into the open air.
  So, it may be possible to obtain somewhat similar results without the long umbilical cord,
which would also allow for a more portable, moveable energy source. Such as  for electric cars, motorcycles, etz...
starcruiser
Remember that Antennas need a ground plane, they are usually the same length to keep the SWR low. So what if the ground plane in this setup is unbalanced? still a 1/4 wave on one side and say a 1/2 wave on the other?
un-balance the dipole to increase the SWR and gain energy extraction???
Regards,
Carl
MenofFather
Quote from: John.K1 on October 29, 2014, 12:42:44 PM... My question is , what is the principle of this Akula /Ruslan /Kapanadze device?...
I have version.
Need kacher ajust to inductor or multilayer coil resonance. Ground lengh can also be important, but seems Ruslan divice must work with any lengh grounding wire.
John.K1
MenofFather.
Ruslan talked about ground cable- its length- as it becomes a part of your coil and will mess up the frequency and that's why there needs to be added some extra wire  to Tesla coil ( in his case more than 5 meters)
