0 Members and 75 Guests are viewing this topic.
John.K1
Hi Itsu, lads
Thank you for your comment. May I ask you how did you select your inductor on your Katcher?  As you can see on the picture  I have tested most of what I have found at home :)  Most of them was overheating. The one as on my  picture seems to stay cool. But I cant get nice sinus shape yet. What would you recommend here. Is it matter of capacitors? The Tesla has its power as you can see 5-6 mm ion stream from the end of the wire and it reads frequency 1.14 which is not a issue at the moment.
Thank for advice.
itsu
Hi John.K1
i guess you mean with "inductor" the common mode choke i see laying around on your bench.
I just grabbed one i had laying around, but as there are some amps running, you need to look for thick wired ones, and
according to Hoppy, it needs to be in the uH range,  not mH.
My present one does not work (the Kacher i mean) when the minus lead is not bypassed on my common mode choke (its 2x 3mH), so i need
to find/build myselve a thick wired / uH ranged one too.
It looks like you are probing the base and collector of your Kacher, right? (scope screenshot)
For checking the output of the Kacher, just lay a probe near the Kacher secondary or antenna and look there for the sine wave,
it probably will be fine.
Regards Itsu
Hoppy
Quote from: itsu on October 31, 2014, 09:14:06 AM
Hi John.K1
Regards Itsu
Even my 300uH choke is too high, so 100uH or less may be OK by re-winding with thick wire.
Hoppy
Void
Quote from: Hoppy on October 31, 2014, 11:39:56 AM
Hoppy
Hi Hoppy. What happens when the choke inductance is too high?
All the best...
