0 Members and 714 Guests are viewing this topic.
d3x0r
Quote from: Void on October 31, 2014, 04:45:34 PM
Hi Hoppy. What happens when the choke inductance is too high?
All the best...
if you have a small capacitance in front of it; it will limit the current, and upset the resonant frequency... adding a larger cap in front of the coil should cover larger chokes ... allowing it to be in a DC mode rather than back oscillating to its supply...
itsu
I made a new Grenade coil according to the now known specifications:
2.5mm² stranded copper wire OD = 3mm, total length is 38.5m with 2x 0.5m connection leads (coil length 37.5m).
Layer 1 and 2 are  19cm long and are resp. 56 and 55 turns CCW
Layer 3 and 4 are 9.5cm long and are resp. 26 and 25 turns CW
Layer 5 and 6 are 4.5cm long and are both 12 turns CW
Tube OD is 5cm
Inductance measured is 168uH @ 1KHz and 166uH @ 100KHz
Main (and almost only) resonance frequency peak is at 1.290 MHz, see screenshot of the frequency scan (1KHz -> 10MHz)
Video here:  https://www.youtube.com/watch?v=2G_nFy4zIek&feature=youtu.be
The Kacher secondary will be wound opposite to the Grenade coil layers 1 and 2 meaning CW
The inductor around the Grenade will be the same wire with a length of 18.75m (half the Greneade length) and wound CW like
the layers 3/4 and 5/6 of the Greneade, but in TESLA BIFILAR way, and probably in 3 layers (2 won't fit on the 9.5cm available).
Tesla bifilar means 1st layer right to left, then straight back to the right and starting there again layer 2 and probably layer 3.
Regards Itsu
URFA
Quote from: magpwr on October 31, 2014, 05:16:16 AM
hi URFA,
I was impressed by your video but at quick glance i have also spotted 2 mistakes.
Please avoid using full-bridge rectifier module at cost although it looks like most easy solution.I have already discussed about this previously that this module is only designed for mains frequency 50/60hz.
The catch is if you try to try at higher frequency in khz range this module won't able to deliver the same Amps as it was rated for.Do check all full bridge recitifer datasheet and it is very rare to spot a module
which can support higher frequency.
Please assemble using diodes like UF5408 3Amp x 2 in parallel for each side to form full-bridge rectifier as an example.
Another previous discussion the full bridge diodes or module inside the 24volts power supply may need to be altered to cater for the high frequency.
Thanks for the video.Keep it up.
Hi magpwr.
You are right, but I've used it for any other purpose,not for rectified voltage end this bridge rectified was unnecessary. Not to have any effect in this my setup.I remove it from the device.
Thanks.
URFA
Quote from: skywalker66 on October 31, 2014, 06:06:44 AM
@ URFA
Hi !
What is hissing in your setup when you move your hand near the cooper antenna ?  Is main yoke, is 24V power source, or something else?
You get interesting effect in deed, seems you are close, but from what I see you may have mess some connections at output side than Ruslan's hand schematic from video, from where probably your large consumption of current. God luck !
Hi skywalker66.
Hissing sound coming from the Common mode inductor.( mini tv yoke in the video). But some times when I change the push pull generator frequency then hissing sound comin from main yoke(20-30%) and mini yoke(Common mode inductor)(70-80).
NickZ
  Itsu and All:
  Nice grenade!  But, now I'm confused...  I had thought that the bifilar coil was wound on the left side of the main grenade coil. And the end of the 48,48, 24,24, 12,12 turns coil was supposed to end up on the right side of the grenade. So, the  bifilar coil should be next to the Kacher coil side, and not on the right side.
  Is this wrong??? Or which way is it, as done by Akula/Ruslan.
