0 Members and 745 Guests are viewing this topic.
magpwr
Quote from: URFA on October 31, 2014, 07:04:59 PM
Hi magpwr.
You are right, but I've used it for any other purpose,not for rectified voltage end this bridge rectified was unnecessary. Not to have any effect in this my setup.I remove it from the device.
Thanks.
Hi URFA,
Thanks for the update.May i ask for your setup do you seperate the yoke core half with insulator or just leave yoke half touching each other.
I have just received the yoke core but i have not done anything yet.
John.K1
Hi Guys,
As I more think about it , I think it does'n matter much which way you have it wound.  As Ruslan said the device consist of two parts  HV Generator and Push-Pull.  HV gives you High potential and Push-Pull is using it to gain energy from the ground.    Check the Aidas picture below I found on old forum. It is pretty close , isn't it? I also did build that one with no success time ago. Now when I think about it, maybe because I didn't puls HV in right frequency as we do in this device??
Hoppy
Quote from: Void on October 31, 2014, 04:45:34 PM
Hi Hoppy. What happens when the choke inductance is too high?
All the best...
Hi Void,
If the inductance is too high, the pulses are attenuated and flattened, as the leading edges are slowed by a restricetd current rate of rise. Like Itsu, I have linked out my choke.
itsu
Quote from: NickZ on October 31, 2014, 09:52:54 PM
  Itsu and All:
  Nice grenade!  But, now I'm confused...  I had thought that the bifilar coil was wound on the left side of the main grenade coil. And the end of the 48,48, 24,24, 12,12 turns coil was supposed to end up on the right side of the grenade. So, the  bifilar coil should be next to the Kacher coil side, and not on the right side.
  Is this wrong??? Or which way is it, as done by Akula/Ruslan.
Hi Nick,
for all i know and have seen,  yes, what you had thought is wrong.
Regards Itsu
Hoppy
Quote from: itsu on October 31, 2014, 06:13:43 PM
I made a new Grenade coil according to the now known specifications:
2.5mm² stranded copper wire OD = 3mm, total length is 38.5m with 2x 0.5m connection leads (coil length 37.5m).
Layer 1 and 2 are  19cm long and are resp. 56 and 55 turns CCW
Layer 3 and 4 are 9.5cm long and are resp. 26 and 25 turns CW
Layer 5 and 6 are 4.5cm long and are both 12 turns CW
Tube OD is 5cm
Inductance measured is 168uH @ 1KHz and 166uH @ 100KHz
Main (and almost only) resonance frequency peak is at 1.290 MHz, see screenshot of the frequency scan (1KHz -> 10MHz)
Video here:  https://www.youtube.com/watch?v=2G_nFy4zIek&feature=youtu.be
The Kacher secondary will be wound opposite to the Grenade coil layers 1 and 2 meaning CW
The inductor around the Grenade will be the same wire with a length of 18.75m (half the Greneade length) and wound CW like
the layers 3/4 and 5/6 of the Greneade, but in TESLA BIFILAR way, and probably in 3 layers (2 won't fit on the 9.5cm available).
Tesla bifilar means 1st layer right to left, then straight back to the right and starting there again layer 2 and probably layer 3.
Regards Itsu
Itsu,
What 'known' specification are you basing your new coils on? Ruslan's latest 'working' grenade coil is wound CW, CCW, CCW. His Kacher secondary is wound CW as is his grenade layers 1&2. His Kacher primary is wound CCW, Antenna CW and inductor is CCW.
Hoppy
