0 Members and 828 Guests are viewing this topic.
Void
Quote from: Hoppy on November 01, 2014, 12:21:07 PM
Here is a shot of my Ruslan replication almost complete build. The scope shot is with the probe just laying on the antenna, which is why the trace is fuzzy. The Kacher was adjusted as close as possible to 1.736MHz with antenna and ferrite choke connected. The length of Kacher secondary coil is 7.5cm. The Kacher primary coil is tapped at about 2.5 turns of the 3 turns to increase secondary voltage which is about 2KV. Current draw is 1.6A.
Nice job Hoppy. What's that yellow 'ribbon' draped over the primary winding of the kacher?
All the best...
John.K1
Nice job Hoppy  ;)
Guys, I have removed hell much of the wire fom Tesla secondary to get it resonate at 1.92MHz. When I connect the Tesla directly to he antenna above the bifilar (grenade) coil, a frequency drop very much to 1.3MHz. Why is that?
  That 2 meters of copper tube cant change the frequency as much , or it can?  I didn't connect it via intermediate ferrite bar yet. Could that ferrite coil solve my problem?
Also when Ruslan was talking with the guys on the Skype, he told them this :  1. Make your granade coil   2. Make your Katcher   3. Tune it to correct frequency   4. quick check with 20W bulb on the bifilar- should lit a bit        .....
Did anybody did this pre-test?  What voltage bulb did you choose? It is not working for me even with  12V 21W car bulb.  My Tesla takes 24V @1.2A.
Thank for advice.
Void
Quote from: John.K1 on November 01, 2014, 03:53:34 PM
Nice job Hoppy  ;)
Hi John.K1. Connecting the 'antenna' coil adds a lot of capacitance to the tesla secondary,
so it is normal for the frequency to drop a fair bit when you connect anything to the secondary coil.
All the best...
Hoppy
Quote from: Void on November 01, 2014, 02:58:53 PM
All the best...
The shot was taken before I had taken the scope shot and I had unwound tape to remove turns from the secondary to adjust frequency.
itsu
Quote from: Hoppy on November 01, 2014, 02:06:51 PM
My Grenade is resonating at about 1.15MHz (with bifilar coil wound over), so quite close to Itsu's. Is this frequency supposed to match to the Kacha frequency because to get down to yours and my grenade frequency would require a much longer Kacher secondary coil length than Ruslan is showing in his videos, or are we supposed to tune the Kacher to our 'earth' frequency (1.736MHz in Ruslan's case)?
Good question, with my bifilar (Tesla way) in place (18.75m + 2x 0.5m connection in 3 layers (3x 27 turns) measuring 245uH) my Grenade peak
resonance frequency even dropped to 900KHz  :o
With my 0.47uF capacitor in place to connect to the 3 turn yoke secondary, the resonance frequency of this bifilar coil has dropped to 14KHz (was 26 with the old grenade / bifilar).
I had to put 3 of those 0.47uF caps in series (0.15uF) to get back to my earlier 26KHz resonance frequency.
I have the same dim output on my 2 60W/220V bulbs as with the old grenade coil.
My Kacher resonates around 1400KHz, so not sure what to do, get it up till 1.7MHz, or down to match the grenade at 0.9MHz
Regards Itsu
