0 Members and 154 Guests are viewing this topic.
MenofFather
Quote from: itsu on November 02, 2014, 05:36:54 AM
Now that i have installed my bifilar coil around the Grenade, that same Grenade resonance frequency has even dropped to 900KHz.
Itsu, can you show that scaning picture with 900 kiloherc resonance? And can you scan inductor wounded on granate (better 11 meters lenght, than 18 meters)?
Hoppy
Nice theory Stupify12,
but considering that my Grenade is now 37.5m (x 4 = 150m wavelength = 2MHz), but as shown, it resonates at 1.3MHz, so
this converting wire length directly into resonance frequency is imo only valid for long wire (antenna's), NOT when coiled up.
Following your theory, i would have to take this 900KHz, take it times 4 = 3.6MHz which would be my Kacher resonance frequency.
This is very high and i doubt it will be reacheable with some degree of power.
Thanks,  regards Itsu
Itsu & all,
I'm getting the distinct impression that nobody here knows how Ruslan tunes his device to the extent that they can provide a clear step by step guide. Am I wrong?
magpwr
hi everyone,
60th SubHarmonics PWM Generator -Part 2
http://www.youtube.com/watch?v=0AyBETNxVa0
In this video i reveal that this divide by 60 PWM generator i created was intended to be running wirelessly merely using the radiated frequency of the tesla coil.
I am using rather long antenna -Croc leads for this video.But for actual build using pcb board with proper shielding i will be using shorter antenna placed near tesla coil.
In this part 2 video i have already revealed how easy it is to tune tesla coil resonance frequency from 2.1Mhz to lower frequency by slowly inserting ferrite rods.
There is no need to waste time by rewinding a new tesla coil if the default resonance frequency is above 2Mhz.
The next upcoming video is about nanosecond 50ns...150ns  injection at high voltage at the 3 turns via 1 wire going  through the toroid(providing nanosecond pulse) which can be made to appear either at the positive peak of the lower frequency eg:28khz or appear at the negative peak merely by connecting to one of the 2 outputs from  divide by 60 PWM generator.
"Tips for the day -Patience and alot of planning is needed before actual experiment which does save on unwanted time.Upon actual experiment just execute all the move you have previously made in your head"
MenofFather
Quote from: Hoppy on November 02, 2014, 07:02:26 AM
Itsu & all,
You not wrong.
Void
Hi Hoppy. I have pointed this out a few times over the last few weeks. :)  This little fact apparently doesn't stop
many people from posting here and telling everyone exactly what they should be doing to get overunity, even though
these same people do not have a self running device.  ;D
The ego is a strange animal. ;)
Don't be discouraged. Keep experimenting to try to understand what makes these devices tick.
This is what I have been focusing on. I am seeing some interesting things, but I still need to
do a lot more experimenting yet. Problem is I am very busy lately so not a lot of free time right now. :)
All the best...
