0 Members and 566 Guests are viewing this topic.
NickZ
  I've rewound my grenade, hopefully the right way, and will install the 12,12, turn inductor coil on top of the bigger output coil today. This inductor needs to be wound the same as the 1st, and 2nd turns of the bigger coil, I take it.  So, that is what I'll do.
  Although it may look like it, but Ruslan is not replicating the Akula second device exactly as Akula has it. There are mayor differences, as he is testing different ways to go about it. And also each new circuit diagram is different, from the previous one, so which one to follow?
Look at this Ruslan video again, which was previously posted by Hoppy.
https://www.youtube.com/watch?v=o6OvRcVPPlY&list=UU_zn0cdzv_qfsxQUm4e7R9w
  Ruslan is explaining many things in the video above, but I don't understand most of it. Maybe someone can point out any important details to consider.  As this is his best most explicit video showing all of the components which are inside both of the junction boxes. Not like before.
GeoFusion
Hi Guyz
  URFA ,
Awesome work man, you are almost there, try know to feed your PSU and filter it with cap to see results when you feel like it. ;)
I have the same results when applying hand or bulb near the antenna, will down freq. and you will hear it and brightness also changes.
Keep us posted, Nice work.
Hoppy, magpwr ,John.K1
Nice work on the Coiling and showing progress guyz,  Hoppy did you manage to light up some light with it yet? the built is very nice.
Gonna share a link and schematic I saw yesterday, very interesting but this is how I tried mines out to first.
I think he drew the bifilar wrongly , should be the Tesla bifilar there but you never know.
Negative rail of Kacher to onside of capacitor of 3winds to bifilar and to grenade coil. is important here.
It reminds me on how the 1st akula Tech was build for only using  the Push pull  TL494 with the 3 winds on ferrite yoke and bifilar inductor for power amplification on coils.
In any case I have attached a Vid on youtube, and the schematic of what this guy is using of the Ruslan grenade device we are currently work on.
It's lighting up 400W halogen.
https://www.youtube.com/watch?v=Z6Vr4Gt8g9o
itsu
Quote from: MenofFather on November 02, 2014, 06:49:59 AM
Itsu, can you show that scaning picture with 900 kiloherc resonance? And can you scan inductor wounded on granate (better 11 meters lenght, than 18 meters)?
Ok,  here the video i made the about the bifilar coil around the grenade.
https://www.youtube.com/watch?v=C4kz3qf0lns&feature=youtu.be
The video about the 11m bifilar coil is not similar as it was a standalone coil,  not interacting with another like this one now.
Regards Itsu
NickZ
  Geo:
   I watched the video that you posted the link to. What it shows is that the Tesla Bifilar way to wind the 12, 12, or the 25, 25 turn inductor coil on the air core can be made to work, either way.
  The first Akula device just pulsed the yoke's 3 turn coil through the capacitor to  the inductor coil which was wound on top the big air core coil. Similar to the video you posted. This was without the 28 turn air coil, as is used now. But, this way if used by itself, is not a self runner, only an inverter crt, if there is no feed back path.
  The first Akula video used a feed back coil on top of the big air coil, connected to the full bridge rectifier, and filter cap, and then back to the power supply unit, to supply the self running input. Without this is it would also just be another an inverter crt.
d3x0r
Quote from: itsu on November 02, 2014, 11:56:12 AM
Regards Itsu
can you measure the resonant ends of the grenade with 2 scope probes?  and attach their ground to a higher point in the ground?  Also attach the ground braid to one side and the other.
Should find different resonant frequencies...but I think that cause you're on the differential of the coil itself that they are hiding....
cyan and yellow dots are scope probe points
