0 Members and 643 Guests are viewing this topic.
Hoppy
Quote from: GeoFusion on November 02, 2014, 11:30:48 AM
Hoppy, magpwr ,John.K1
Nice work on the Coiling and showing progress guyz,  Hoppy did you manage to light up some light with it yet? the built is very nice.
Thanks Geo. Yes, I can light a 10W mains lamp but its early days for my tuning. I've spent some time today knocking-up a basic 24V / 10A  transformer based power supply for testing purposes. Its just a 18V / 16A toroid transformer, FWBR and 10,000uF smoothing cap.
magpwr
Hi Guyz
  URFA ,
Awesome work man, you are almost there, try know to feed your PSU and filter it with cap to see results when you feel like it. ;)
I have the same results when applying hand or bulb near the antenna, will down freq. and you will hear it and brightness also changes.
Keep us posted, Nice work.
Gonna share a link and schematic I saw yesterday, very interesting but this is how I tried mines out to first.
I think he drew the bifilar wrongly , should be the Tesla bifilar there but you never know.
Negative rail of Kacher to onside of capacitor of 3winds to bifilar and to grenade coil. is important here.
It reminds me on how the 1st akula Tech was build for only using  the Push pull  TL494 with the 3 winds on ferrite yoke and bifilar inductor for power amplification on coils.
In any case I have attached a Vid on youtube, and the schematic of what this guy is using of the Ruslan grenade device we are currently work on.
It's lighting up 400W halogen.
https://www.youtube.com/watch?v=Z6Vr4Gt8g9o
Hi Geo,
Thanks for posting this circuit diagram.This looks more logical esp at ground connection after 100uh common mode choke at tesla driver circuit.The transistor emitter for tesla coil is connected to ground wire directly.
skywalker66
Quote from: itsu on November 02, 2014, 11:56:12 AM
Ok,  here the video i made the about the bifilar coil around the grenade.
https://www.youtube.com/watch?v=C4kz3qf0lns&feature=youtu.be
The video about the 11m bifilar coil is not similar as it was a standalone coil,  not interacting with another like this one now.
Regards Itsu
Hi Itsu!
After winding inductor coil, now you have 2 coils with 2 different resonant frequency, therefore the response at signal generator stimulation will be a combination of the two frequencies. A very nasty business...
For finding new frequency, you may try this:
1. Connect a 0.47uf across your inductor, and put to ground the upper leg of inductor. This will disable the influence of free oscillating of inductor on resonant freq. of grenade.
2. Put your test coil from FG across 6-th layer of your grenade.
3. Put oscilloscope ground to upper leg of grenade, and between scope probe and lower leg put 100k resistor, scope probe set on 10x - for keeping as minimum as possible influence of probe's capacity on resonant freq. of grenade
4. Sweep FG for max. amplitude on oscilloscope. You will find new freq. somewhere between 1.6 - 1.8 MHz. That will be the freq for kacher shutting of.
I hope this will help.
PS: This is just a theoretical speculation of mine, and get as such.
itsu
Quote from: d3x0r on November 02, 2014, 04:40:07 PM
can you measure the resonant ends of the grenade with 2 scope probes?  and attach their ground to a higher point in the ground?  Also attach the ground braid to one side and the other.
Should find different resonant frequencies...but I think that cause you're on the differential of the coil itself that they are hiding....
cyan and yellow dots are scope probe points
Thanks  d3x0,
it will be hard to do as my ground high point is not near my bench, so have to look into it.
Regards itsu
itsu
Quote from: skywalker66 on November 03, 2014, 01:29:52 AM
Hi Itsu!
Thanks Sky,
i can try that, at the moment tuning with a ferrite rod inside the Kacher secondary (like Magpwr suggested), but no sign of
my 2x 60W bulbs getting any brighter, so need a more defenitive frequency to set my Kacher.
Regards Itsu
