0 Members and 151 Guests are viewing this topic.
skywalker66
Quote from: itsu on November 03, 2014, 03:24:04 AM
Thanks Sky,
i can try that, at the moment tuning with a ferrite rod inside the Kacher secondary (like Magpwr suggested), but no sign of
my 2x 60W bulbs getting any brighter, so need a more defenitive frequency to set my Kacher.
Regards Itsu
No need bulbs yet. Just find the new freq. of your grenade with the inductor on it as I suggested above.
After that, tune your series resonance (3 turn + capacitor + inductor) on Freq. grenade / 50 by choosing apropriate cond for series resonant circuitry. Then tune kacher using whatever method is suited for you to match  grenade freq.
skywalker66
@ Itsu
Basicaly as I've understand there are two main frequencies:
1. Grenade natural freq must match kacher freq.
2. Series resonant circuitry = F grenade / 50. Push-pull driver must drive yoke on this freq.
PS. With 3 layer inductor, coil assembly look too bulky than what I see in all Ruslan's videos. I'm convinced Ruslan use just 2 layers (Tesla mode), and  18.5m for inductor is obvious not true, maybe 1/4 from grenade length, but not 1/2.
itsu
Quote from: skywalker66 on November 03, 2014, 04:10:49 AM
@ Itsu
I agree, but 1/4 would be only 9.3m.    I keep it in mind, if other tuning methods do not yield any success.
Regards itsu
magpwr
Thanks Sky,
Regards Itsu
Hi itsu,
Only the divide by 60 pwm circuit i have created and posted would be dependent on tesla coil.To easily find resonance  of capacitor in series with 3 turns just apply signal generator in series with 1kohm resistor with circuit as shown in my video part 1.
Jeg
Quote from: URFA on October 31, 2014, 03:45:44 AM
Hi Void.
In fact you know everything about my setup. I used Ruslan's schematic. He drew in his video. His scheme was published by Enjoykin and GeoFusion.It was posted a few pages ago in this forum.
In my setup.
Hi guys, its been a while since my last post. I can safely state that tuning is a real pain in the ass. Or even better, tuning is a beach! :D
Well, Skywalker is very close but in practice it is even more difficult. You have two different lines, with different self frequencies interacting between each other. That means that by winding your inductor you have to find the gold point where both lines are ringing together to the same frequency. You test each line by each time disconnecting the other. If you are wavelength matched between the lines, then start unwinding your inductor turn by turn until to reach this gold point. The better way for watching the results is to first tune both lines to a same low KHz frequency, and then by attaching your probe in parallel with the tuning caps just sweep and see the high frequency peaks and ringing. When you finally match them put them both in line and measure inductively the common frequency vibration by placing your probe as a two turns receiver around both coils (thin side). All this calibration is without ground in place. Ground is a third line which also needs synchronization as it also has its own ringing which have to be matched. And no. What ever ringing you will measure at the ground line is not a telluric current. It is the self oscillation of the ground cable. If you attach it in place and your previous interaction frequency doesn't change, then you are fine.
Ibrahim Urfa!
What can I say about you my friend! Even a big bravo is not enough. You made your first steps on the other side... well done! I just have a question. I saw in practice that even with a well balanced and tuned system things are not getting easier. I mean, I use the same ruslan's drawing but I can't trap radiant energy inside my coils system. I will keep trying in case that I overlook something, but I feel that something is missing from the drawing. Is that true? Or it is just a matter of correct coils orientation and winding directions? Just a yes or no would be enough for us to look to the right direction for an answer.
Thanks Jeg
