0 Members and 623 Guests are viewing this topic.
T-1000
Quote from: skywalker66 on November 03, 2014, 08:05:40 AM
I have a hunch that inductors length is not mater at all, even inductor itself is not so important across grenade, can be made separately, but please don't tell anyone, people do not like that, they get nervous if inductor haven't exactly 18.5m ;D
In regards to wire length of grenade coil you need to see on what frequency Earth grounding responds best with different coils before doing calculations. The way to see what is happening is quite simple with frequency sweep generator powered by not grounded power source and test coil attached with one end to the generator and second end to ground. The current probe for spectrum analyzer/scope should be on the ground wire. Then trying different coils you might see on which frequency response is on same peaks and dividing that wavelength by 4 will be your grenade coil wire length.
Cheers!
Hoppy
Quote from: itsu on November 03, 2014, 07:51:17 AM
11m he, could it be somewhat more,  like 12.5m as it would be 1/3 of the grenade wire length (37.5m)
This 12.5m will fit nicely as 2 layers.
Regards Itsu
Itsu,
I agree, I have stripped off the top layer from my inductor and I have about 13m including connection tails. I looked very closely at all the available shots of Ruslans coil assembly and I'm sure there are only two layers. Also, why would a bifilar coil wound this way (stacked layers) logically have three layers.
Hoppy
itsu
Quote from: Hoppy on November 03, 2014, 08:14:03 AM
Itsu,
Hoppy
The only reason for this bifilar coil to have 3 layers is to accommodate the 18.75m wire length on the available 9.5cm space.
Regards Itsu
MenofFather
Itsu you can look osciliograms acording this schematic http://realstrannik.ru/media/kunena/attachments/3866/ruslanschemapodkliuchenia.png
Diodes can use UF5408. You curent probe is not good because it have resistor on secondary windings. Need big permability feritte ring to get that pulses, not on all ferite rings, you get that pulses. I get that pulses, but I not have two chanel oscilioscope.
NickZ
  There are no replications shown made using 18.75 meters for the inductor coil, none. Ruslan may just be guessing, without trying it out himself, nor showing it working as such.
   I just measured my 12,12 turn coil for my grenade inductor coil (12v set up), and it is was 16 foot, 5 inches long. I don't have a metric tape measure, I just provide this in measurement in feet, as a comparison. So, if anyone is interested they can just convert it to meters.
  11 meters sounds about right for the 24v systems, as a starting point.
  Itsu: Why not just remove one layer of the three on your inductor and try it again.
  Previously the primary yoke coil was only 6, 6 turns, for the 12v set up, and double that for the 24v system. That is where the magnetic induction is being produced from. If you don't get a 100 watt bulb to light brightly at this point, there may be something that needs to be further tuned, to continue on.
  All: This lasersaber video (below) shows the way he tunes his coils for maximum output. Please skip to minute 4.47, on.
  This may help some to obtain a higher output for any device, than just barely lighting a bulb or two, and hoping that the rest of the circuit will make up for it.
  https://www.youtube.com/watch?v=vVXzGcyzu6o&list=UUIKzUKkh7XtnSYPW0AJb-9w
