0 Members and 144 Guests are viewing this topic.
MenofFather
Itsu, can you scan bifilar inductor in range 0.1-10 megaherc like in image?
Oscilioscope conect were red dots. Inductor lengh can be and 18 meters, but better 11 meters. Inductor can be wounded on multilayer coil or on 5 cm diameter tube, better on tube.
Hoppy
Quote from: GeoFusion on November 03, 2014, 03:35:59 PM
Hi Guyz,
Hoppy, magpwr,
No problem guyz, Here for the help and for progression of replication.
But keep it up, as we see in Meno's recent vid, the Inductor pulses are producing energy in the grenade with the help of ground and
kacher's ground connected to it too, Without the 28 winds of yoke connected.
This show's that this Inductor can be used to excite a Tesla coil, Was drawn by akula some time ago.
Hoppy, now that you have changed to a  0.22uf cap and showing 160Vpp, see if you can light up that 10W bulb. see if there is change.
Cheerz
Hi Geo,
My measurements and experiments are showing that the energy in the inductor is governed by the number of yoke turns and its the grenade that's inducing current in the inductor, not the other way round. In turn, current is being induced into Meno's toroid and the high inductance of the high permeability toroid is causing the pulses we see on the scope. As he says, if a resistor is connected in series with the toroid secondary winding (primary is the single wire passing through the toroid), then a sine-wave is seen on the scope. Therefore, the wave shape is a being affected by the characteristics of the toroid.
I can light the bulb without the inductor in circuit. Its the induced current in the 28 turn winding that's lighting the bulb. The inductor has negligible affect on the bulbs brightness. This is why I'm waiting for an explanation as to the function of the inductor.
Acca
itsu
Quote from: T-1000 on November 03, 2014, 08:13:05 AM
In regards to wire length of grenade coil you need to see on what frequency Earth grounding responds best with different coils before doing calculations. The way to see what is happening is quite simple with frequency sweep generator powered by not grounded power source and test coil attached with one end to the generator and second end to ground. The current probe for spectrum analyzer/scope should be on the ground wire. Then trying different coils you might see on which frequency response is on same peaks and dividing that wavelength by 4 will be your grenade coil wire length.
Cheers!
Hi T-1000,
i tried to follow your suggestion, but where should i put my black return lead of my "not grounded FG"?
Regards Itsu
itsu
Quote from: MenofFather on November 03, 2014, 04:16:28 PM
OK, i used my earlier made 11m wire Tesla Bifilar coil on a 5cm OD tube.
I used my 3 turn secondary from my yoke connecting to the series 0.47uF cap and drove this yoke with my FG with 2 turns loosly wrapped around it.
I see a single strong resonance peak around 7MHz
Regards Itsu
