0 Members and 67 Guests are viewing this topic.
Void
Quote from: itsu on November 03, 2014, 04:40:40 PM
Hi T-1000,
i tried to follow your suggestion, but where should i put my black return lead of my "not grounded FG"?
Regards Itsu
Hi Itsu. In such a case you could leave the ground lead of the FG unconnected.
From my own tests with this, I don't think you will likely come up with
one common frequency testing with different coils. Frequencies where you will see peaks
in the coil and ground wire will depend on resonance points in whichever specific coil you are using.
I personally don't think this is the answer, but it will be interesting to see if you get any much different
results than I did in my tests with this approach. :)
All the best...
itsu
Hi Void,
i did left it floating, but like you said, 2 different coils show 2 different sweep responses.
But then i realized that i synced my ungrounded FG with my grounded scope (coax cable), so at that time the FG was also grounded  >:(
I agree with you that this is not the way to go.
Regards itsu
Void
Quote from: itsu on November 03, 2014, 04:56:27 PM
OK, i used my earlier made 11m wire Tesla Bifilar coil on a 5cm OD tube.
I used my 3 turn secondary from my yoke connecting to the series 0.47uF cap and drove this yoke with my FG with 2 turns loosly wrapped around it.
I see a single strong resonance peak around 7MHz
Regards Itsu
Hi Itsu. That's interesting. Did you have the 11m 'bifilar inductor' wound over a grenade coil?
It may possibly have been the grenade coil that was resonating at that frequency, but maybe it was
the bifilar inductor coil.  At any rate, such resonances do not seem to correspond to how Akula and Ruslan
have explained things, but you just never know at this point. ;)
Whether it has any real significance or not, 7MHz / 4 = 1.75 MHz.  It's definitely interesting anyway.
P.S.  So you have the series resonance of that loop at 32 KHz or whatever you are tuned to, and at the same time
another resonance in the same loop at a little over 7 MHz.  That has me thinking......    hmm...  Maybe it
is something to do with these sort of dual resonances that we are aiming for? Akula wondered about this
himself in a comment on one of his schematics. I don't know if this is the right line of thinking or not though...
All the best...
John.K1
Check List:
Granade coil :  DONE
Katcher:  DONE (+ grounded emitter o transistor)
Tuning antenna to Granade coil ( 1.85MHz considering speed of electrons in copper 96 % of speed o light):  DONE
Pre- check -Light 220V 20W one end on grenade coil:  PASSED  (light lit a bit)
TV choke : READY-wound
Push-Pull: Awaiting parts
So far I do not see any difference as I used completely different diameters of wires and three layers of inductor. May-be problems will rise later on :)
Void
Quote from: John.K1 on November 03, 2014, 05:09:51 PM
Check List:
Granade coil :  DONE
Looks like you are making good progress John.
All the best...
