0 Members and 173 Guests are viewing this topic.
magpwr
Quote from: Hoppy on November 03, 2014, 05:54:42 PM
OK, but please explain what you mean by your sentence: "This is after nanosecond pulse injection as provided by Ni-Zn toroid which is already in place in your device."
What I'm really getting at here, is why do you think nano-pulses are needed to be injected into the inductor circuit? Memo has the same waveform as that shown by Ruslan and shown that it is not related to nano-pulses.
Hi hoppy,
I have previously mentioned twice that tesla detected his coil was generating ether after applying the knife/nanosecond pulse.
Please just wait for meno to do candle test first.
I may have good memory but i dont have the virtue of a teacher to keep repeating the same thing every 2 or 3 weeks.
Any pulse width which is less than 1us/div would still qualify as nanosecond pulse
T-1000
Quote from: itsu on November 03, 2014, 04:07:36 PM
Hi Sky,
i followed your steps, but i find a strong resonance peak on the Grenade at 500KHz, see screenshot.
Using severall other ground points and/or scope points i see different peaks, but no strong / single one around the 1.6 - 1.8MHz range.
Video here:  https://www.youtube.com/watch?v=gMLgvSw-omg&feature=youtu.be   (still uploading.....)
Not sure why my Grenade measures so low, perhaps i should remove 1 layer from the inductor coil.
Regards itsu
Hi itsu,
The LC resonant points will shift with any influence added. However, the main thing here is to treat grenade coil as waveguide and the wire length determines the frequency  with regardless to any LC resonant frequencies... Also the standing wave inside of coil should form on point where opposite winding is introduced and the grounding adds virtual wire for calculation. The SWR readings should help as well just we are looking for opposite from conventional readings when trying to get wave reflections in correct grenade coil spots for standing wave.
Cheers!
NickZ
  I got my grenade rewired now, hopefully the correct way. 48,48, 24,24, 12, 12 turns.
The inductor (or resonator coil) is also installed and is 12, 12 turns, as I'm using a 12v battery for the input.
I'll make a new Kacher antenna tomorrow, and mount it, as well.
  Here's a pic of the my newly rewound grenade.
MenofFather
Quote from: magpwr on November 03, 2014, 05:37:02 PM
hi MenofFather,
Thanks for the explanation.
Short experiment to conduct if your antenna is generating ions instead of more rf which is wasted-
This is the interesting part in order to know if your antenna from tesla/kacher coil is generating more negative ions(ionizer) instead of more RF output.
Can you assist to try holding a small candle near the antenna over the 25x2 coil and see if it is getting blown as shown in video below in order to detect present of ions if my theory is correct in order to know if there is presence of ion wind.
Long story short-Take candle place near antenna to see if it is getting blown upon. :)
Negative Ions Generator(Using candle to detect ions)  Just skip video to 6minutes onwards to save time
http://www.youtube.com/watch?v=MReUF8n8U74
Pulses on secondary curent transformer is not nanosecond pulses. And they only is on secondary, on primary is no pulses. That curent transformer Ruslan can use for automatic resonance ajustion betwen inductor and 0,47 uF capasitor.
MenofFather
Itsu or any body other (who have two chanel oscilioscope), can now you try make like in that schematic http://realstrannik.ru/media/kunena/attachments/3866/ruslanschemapodkliuchenia.png and then turn on kacher and turn off, to see or sine on multilayer coil is moving to one or other side, then kacher is turned on?
Ground can be were is not punctir and were is punctir line.
