0 Members and 75 Guests are viewing this topic.
Hoppy
Quote from: magpwr on November 03, 2014, 06:25:49 PM
Hi hoppy,
I have previously mentioned twice that tesla detected his coil was generating ether after applying the knife/nanosecond pulse.
Please just wait for meno to do candle test first.
I may have good memory but i dont have the virtue of a teacher to keep repeating the same thing every 2 or 3 weeks.
Any pulse width which is less than 1us/div would still qualify as nanosecond pulse
Mag,
I'll repeat for the last time, there are no nano pulses being injected into meno's device!  See his post above where he repeats this confirmation.
MenofFather
Hoppy
Quote from: NickZ on November 03, 2014, 09:11:20 PM
  I got my grenade rewired now, hopefully the correct way. 48,48, 24,24, 12, 12 turns.
The inductor (or resonator coil) is also installed and is 12, 12 turns, as I'm using a 12v battery for the input.
I'll make a new Kacher antenna tomorrow, and mount it, as well.
  Here's a pic of the my newly rewound grenade.
Hi Nick,
What diameter pipe are you using?
Hoppy
Attached is a scope shot of the current waveform (moustache) taken from my current transformer and voltage waveform across inductor cap. The frequency reading shown is not stable and is actually 33.3KHz.
itsu
Quote from: Void on November 03, 2014, 05:06:45 PM
Hi Itsu. That's interesting. Did you have the 11m 'bifilar inductor' wound over a grenade coil?
It may possibly have been the grenade coil that was resonating at that frequency, but maybe it was
the bifilar inductor coil.  At any rate, such resonances do not seem to correspond to how Akula and Ruslan
have explained things, but you just never know at this point. ;)
Whether it has any real significance or not, 7MHz / 4 = 1.75 MHz.  It's definitely interesting anyway.
P.S.  So you have the series resonance of that loop at 32 KHz or whatever you are tuned to, and at the same time
another resonance in the same loop at a little over 7 MHz.  That has me thinking......    hmm...  Maybe it
is something to do with these sort of dual resonances that we are aiming for? Akula wondered about this
himself in a comment on one of his schematics. I don't know if this is the right line of thinking or not though...
All the best...
Void and Magpwr,
I used the setup as requested by MenofFather here:
http://www.overunity.com/12736/kapanadze-cousin-dally-free-energy/msg422138/#msg422138
He mentioned that it would be better to use a standalone 11m bifilar coil:
QuoteInductor can be wounded on multilayer coil or on 5 cm diameter tube, better on tube.
So i used a standalone, 11m wire, Tesla bifilar, (2 layers) coil on a bare 5cm OD tube.
It was connected to my 3 turn secondary on my yoke (which also has the 28 turn secondary and the 2x 6 turn primary) via a 0.47uF series capacitor.
Sweep signal was injected from my FG via an extra loosly coupled 2 turn wire around the yoke.
I did have a (very small amplitude) resonance peak around 25KHz, but its not visible in the sweep picture, but
i guess thats the resonance peak created by the series LC of this 11m coil and the 0,47uF cap.
But the main peak was on 7MHz, which is strange in my eyes as i swepped this same coil before and it showed a single
resonance point of 2MHz, see here:
http://www.overunity.com/12736/kapanadze-cousin-dally-free-energy/msg421340/#msg421340
I did not have it connected to anything else then my scope probe points then (unloaded).
Regards itsu
