0 Members and 566 Guests are viewing this topic.
itsu
Quote from: Hoppy on November 04, 2014, 03:29:25 AM
Attached is a scope shot of the current waveform (moustache) taken from my current transformer and voltage waveform across inductor cap. The frequency reading shown is not stable and is actually 33.3KHz.
Hi Hoppy,
that looks very similar as the Ruslan scopeshots.
What are you using for current sensor and where in the circuit is it?
Thanks,  regards Itsu
itsu
Quote from: T-1000 on November 03, 2014, 07:23:14 PM
Hi itsu,
The LC resonant points will shift with any influence added. However, the main thing here is to treat grenade coil as waveguide and the wire length determines the frequency  with regardless to any LC resonant frequencies... Also the standing wave inside of coil should form on point where opposite winding is introduced and the grounding adds virtual wire for calculation. The SWR readings should help as well just we are looking for opposite from conventional readings when trying to get wave reflections in correct grenade coil spots for standing wave.
Cheers!
Thanks T-1000,
i see where you are going, but thats an area which has its own special technics  :o
Regards Itsu
itsu
Quote from: MenofFather on November 04, 2014, 01:55:01 AM
Itsu or any body other (who have two chanel oscilioscope), can now you try make like in that schematic http://realstrannik.ru/media/kunena/attachments/3866/ruslanschemapodkliuchenia.png and then turn on kacher and turn off, to see or sine on multilayer coil is moving to one or other side, then kacher is turned on?
Ground can be were is not punctir and were is punctir line.
MenofFather,  i can try that, but as mentioned before, my current probe, or current transformer used does not show this
spiky current signal, perhaps Hoppy can show me how.
Regards itsu
Hoppy
Quote from: itsu on November 04, 2014, 03:34:53 AM
Hi Hoppy,
Itsu,
I'm using a high permeability toroid (20mm x 10mm) colour coded orange with a 12 turn secondary winding of thick ECW. The primary is one wire of the inductor coil just passing through the toroid as in meno's and Ruslan's videos. The toroid was a common-mode choke taken from an induction cooker mains filter unit. I stripped off one half of the winding.
Hoppy
MenofFather
Quote from: itsu on November 04, 2014, 03:44:08 AM
Regards itsu
You not need use curent probe. You need mount on inductor wire, going to 3 turns on yoke, ferite ring like in my video (https://www.youtube.com/watch?v=lqcigiQcyPQ) with wounded 6-12 turns and to that turns conect oscilioscope.
And if you can please scan multilayer coil with conected to it 100 omh resistor (or if not have, then any, that you have 10-5000 omh) and without that resistor.
