0 Members and 80 Guests are viewing this topic.
magpwr
Quote from: Hoppy on November 04, 2014, 02:43:07 AM
Mag,
I'll repeat for the last time, there are no nano pulses being injected into meno's device!  See his post above where he repeats this confirmation.
Hi hoppy,
No worries.I will inject nanosecond 50ns to 150ns for my device which was the plan for my next stage of my experiment anyway.
skywalker66
Quote from: itsu on November 03, 2014, 04:07:36 PM
Hi Sky,
i followed your steps, but i find a strong resonance peak on the Grenade at 500KHz, see screenshot.
Using severall other ground points and/or scope points i see different peaks, but no strong / single one around the 1.6 - 1.8MHz range.
Video here:  https://www.youtube.com/watch?v=gMLgvSw-omg&feature=youtu.be   (still uploading.....)
Not sure why my Grenade measures so low, perhaps i should remove 1 layer from the inductor coil.
Regards itsu
Thanks Itsu for giving a try for this and for your time.
I do the same as you 2 days before, grenade coil + inductor with 3 layer, Tesla mode, but I get peak at 1.64Mhz frequency, in almost same condition.
The difference was I scan manual FG for peak freq, but isn't relevant, I think.  I use for my grenade coil and inductor, 2.5mm2 solid cooper cable with pvc isolation.
Seems this frequency is very sensitive and very hard to catch.
I still trying to find a valid method for shutting real resonant freq of grenade for which must tune kacher.
Regards !
Hoppy
Further testing using the ferrite transformer, shows that obtaining the sharpest mustache waveform is dependant on the inductor circuit being near to or at LC series resonance. At resonance, the tip of the mustache sharpens and aligns with the peak of the sine wave - voltage and current in phase. I can achieve this with 210nF of capacitance.
skywalker66
Quote from: T-1000 on November 03, 2014, 07:23:14 PM
Hi itsu,
The LC resonant points will shift with any influence added. However, the main thing here is to treat grenade coil as waveguide and the wire length determines the frequency  with regardless to any LC resonant frequencies... Also the standing wave inside of coil should form on point where opposite winding is introduced and the grounding adds virtual wire for calculation. The SWR readings should help as well just we are looking for opposite from conventional readings when trying to get wave reflections in correct grenade coil spots for standing wave.
Cheers!
You say self resonance frequency of a coil determined by inductance and interwinding, interturn  capacity of coil is different from standing wave frequency in same coil ?
John.K1
Hi Guys,
I would like to know opinion.  I got shocked yesterday by the coil lying nearby the device. Than I realize the question how much are components sensitive to this field. Mainly capacitors. Can all this ruin or to help to reach effect?.  Should we shield or expose our electronic device to that field??
