0 Members and 567 Guests are viewing this topic.
itsu
Quote from: MenofFather on November 05, 2014, 01:40:58 AM
Itsu, can you put curent transformer  now were is red dot, betwen one end inductor and capasitor?
I can, but that point is/was grounded as per the latest diagrams!
Regards Itsu
itsu
Quote from: MenofFather on November 05, 2014, 02:10:39 AM
Itsu and can you scan like in schematic in this post again, but first oscilioscope probe to one end conected who grounded to uper dot, then grounded end of oscilioscope conected to buttom red dot? Because oscilioscope one end is grounded riht?
http://www.overunity.com/12736/kapanadze-cousin-dally-free-energy/msg422138/#msg422138
Ok,  will try tonight,  yes the ground lead of the probe is grounded at the same common ground i have.
Regards Itsu
Jeg
Guys I need your experience.
First of all, this current transformer that you use in the 3T line, doesn't alter the phase of the line? Do you think that this is the case? Well, lets describe what I have implement until now so to understand what happens to my construction so to be easier to track my mistakes.
I use the same schematic as Ruslan's handrawing. The 3T line consisted only of the tuning cap and the inductor. The 28T line is as you see it in the schematic. 28T in series with grenade, and at the other side the diode charging the 10uF cap through a choke.
After tuning it and fixing some directions of my coils, I managed to pass the high frequency oscillation into my main grenade line. 200V pk-pk from katcher exactly at the center of the pulse. My initial problem which I faced yesterday was that the imposition of the signal to the low freq signal, didn't affect my bulbs at all! See attachment. Then I put an other diode from grenade to ground. Anode to grenade, cathode to ground. The resulted waveform changed a little and I noticed that a very weak energy added to my bulbs but it is not as strong interaction as at Urfa's video. I suspect that my katcher needs to re wounded on the other direction. But, I think that what ever winding direction you do to your katcher, the result is the same. Only negative particles at the antenna. Is that true? Did you notice something different by changing direction at kacher side?
First set of waveforms is the low freq signal at the cathode of the diode before the 10uF cap, and the voltage at the 3T line as taken at the leads of the cap. Second set of waveforms when katcher on fire. Third waveform that I will attach later cause I don't have an available shot right now, is when I added the second diode between grenade and ground.
Do you have something to note?
Jeg
As i see it, the katcher high freq voltage, imposed exactly at the middle. If I could move it to the upper side then I will have an average increment. But the way it is imposed the average is the same as zero. I wish my English to be better.
Jeg
This is with the added diode. Nothing extremely different but as I told you there is a small increment of my bulb light, with a small decrement of current at the input!. As you see this time katcher's signal moved a little to the zero line, so average voltage changed a little. How can I move this oscillation on the top of the low freq signal? Some diodes missing I think.
