0 Members and 563 Guests are viewing this topic.
Hoppy
Quote from: magpwr on November 05, 2014, 05:18:34 PM
hi Hoppy,
Thanks for reporting this latest findings of valuable interest.Hopefully we can see a short video soon to watch the bulb pulsing.
"This is good news for me in the morning"
Hi Mag,
it is a very short couple of flashes after power disconnection but hopefully, this might be an indicator that I'm getting close. There is a very narrow window where the position of the ferrite will cause the pulsing. The pulsing frequency can also be controlled by very small alterations to the inductor cap around the resonance point. With regards to doing a video, I will need to get my son to assist me with the making of a video when he has some spare time.
magpwr
Quote from: Hoppy on November 05, 2014, 05:53:54 PM
Hi Mag,
Hi hoppy,
Recall the 60th sub-harmonics generator i have posted.It was design for this to ensure the both waveform stays aligned without run off.Take note circuit just needs to be tuned once to ensure both output produce nearlythe same duty at around 47% and ensure both output have around equal 750ns deadtime gap between 2 outputs before connecting to mosfet.
MenofFather
Quote from: Jeg on November 05, 2014, 01:01:12 PM
Hi Menof how are you doing :)
Now I good.
QuoteYou mean that either cw or ccw it outputs the same particle sign?
I think, yes.
MenofFather
Quote from: itsu on November 05, 2014, 03:32:59 PM
ok, done, see screenshot.
Bifilar (tesla) was 13m in 2 layers around the Grenade.
White trace  is with ground lead of the scope probe at upper dot,
yellow trace is with ground lead of the scope probe at bottom dot.
Regards Itsu
Here one megaherc per division?
MenofFather
Quote from: itsu on November 05, 2014, 04:17:19 PM
Ok,  now i see what you mean,  in the below picture taken from this Ruslan Video https://www.youtube.com/watch?v=C8RcRlzk16w,
it can be seen that the SECOND trace show without the Kacher activated, the current (spiky signal) through the 3 turn secondary/bifilar coil is trailing 90°
the sine wave which is the voltage from the Grenade before the FWBR and Cap.
A trailing current means no resonance (as confirmed by the low voltages seen) and at the inductive side of the resonance.
While in the FIRST trace we see suddenly when the Kacher is activated, the voltage now 180° out of phase with the current spikes.
I tried the same (ungrounded), but even when detuning out of resonance, the current spikes and the voltage stay more or less in the same phase relation with or
without the Kacher.
(it could be that one of the probes was reversed (on the current transformer f.i.), which means that with the kacher activated (first trace)
the voltage and current ARE in phase, and without the Kacher active (second trace) the current is LEADING 90° the voltage, meaning
out of resonance at the capacitive side!!)
Regards Itsu
Itsu, in Ruslan phase shift is 90 degree without kacher. Why you can not get that 90 degree without kacher?
