0 Members and 68 Guests are viewing this topic.
NickZ
   Itsu:
   Seams like you're getting close...
   I would try tuning using some different caps, with the Kacher on, as well.
   I have noticed the same thing, as far as that the higher amplitude does not always mean brighter bulbs.
   I would still try on different wattage bulbs, as they are also part of the circuit, and have much influence on the output and bulb brightness generated by the device.
magpwr
Quote from: Hoppy on November 06, 2014, 03:27:14 PM
Some more encouraging news. I changed the load to a 40W clear bulb so that I could clearly see the glowing filament. On the previous experiments, I had forgotten to carefully insert the ferrite rods into the Kacher tube to tune frequency to 1.316MHz. I was just pushing the rods up and down the tube and of course constantly changing the Kacher frequency  - doh!. ::) Now having tuned properly, I can clearly see that as the Kacher waveform approaches maximum amplitude, the lamp filament does start to pulsate and I can change the pulse frequency by making very slight adjustments to the positioning of the ferrite rods.  :) The bulb also changes slightly in brightness level. I'm getting a short purple streamer off the end of the antenna. The Kacher frequency without the ferrite rods inserted is about 2MHz.
hi Hoppy,
May i ask the "frequency of the PWM generator" which you previous set to get bulb to go into pulsing mode.
We now know your Kacher Frequency is 1.316Mhz
I merely wanted to know from your end if at 60th harmonics which waveform is aligned only then you get to see a pulsing bulb.
At my end no progress was done for last few days since the video.Only some basic fact findings on capacitor which i have mentioned less than 24hour ago.
At my end the pending 2 outer coil is not added along with cw,ccw on ferrite rod.
I will start with outer coil today along with cw,ccw ferrite rod but no support for pvc pipe.Just using the box as shown in video for now.
MenofFather
Thank you, Itsu. And can you show that be like in that picture?
Multilayer coil, diodes and capasitor can be not removed.
itsu
Quote from: Hoppy on November 06, 2014, 04:54:39 PM
Hi Jeg,
Yes, that's a thought but I'm getting a 5mm streamer from the end of the antenna, so I'm not sure that more voltage is really needed?
Hoppy,
5mm is very long, is that across the whole "tuning range" when using the ferrite or does it peak at a certain frequency?
My Kacher is running at 1.9MHz at 36V / 1A, but produces minimum streamers then of 0.5mm, but when tuning with the
ferrite rod, it peaks around 1.1MHz with 3mm streamers (tuning done via scope probe laying nearby for max. amplitude).
Regards itsu
magpwr
hi everyone,
This is my latest findings in the afternoon at resonance to achieve maximum peak to peak voltage across 1uf.I noticed the bulb isn't as bright.Until i approach just close to resonance to observe the
similar bulb brightness as shown by itsu in the most latest video as posted around 24hours ago.
Another interesting discovery upon connecting 5uf 900volts snubber capacitor in parallel with 60watt bulb.There is increase in bulb intensity noted.
I have attached to show the difference with and without 5uf 900volts snubber capacitor which is connected in parallel with the bulb.
I have completed windings 28turns and 12-0-12 turns using 4mm sq on my nano-crystalline toroid.
I am now using the attached circuit diagram related to connection to bulb with 600volts diode at the kapanadze winding.
The attached watt meter is the total power consumption which also includes the kacher coil which the antenna is not assembled.
Side Note-The 3 turns to 28 turns on my toroid reminded my of my ultra lowest low voltage 25mV joule thief which the source is the high current but low voltage peltier.
Since i also recall Akula did mentioned about current movement.This is where the 3.5 turns 6mm sq wire come into play from the earth.
The outer winding over 25 turns will be completed later.
