0 Members and 1510 Guests are viewing this topic.
Hoppy
Quote from: magpwr on November 06, 2014, 08:33:10 PM
hi Hoppy,
May i ask the "frequency of the PWM generator" which you previous set to get bulb to go into pulsing mode.
We now know your Kacher Frequency is 1.316Mhz
I merely wanted to know from your end if at 60th harmonics which waveform is aligned only then you get to see a pulsing bulb.
At my end no progress was done for last few days since the video.Only some basic fact findings on capacitor which i have mentioned less than 24hour ago.
At my end the pending 2 outer coil is not added along with cw,ccw on ferrite rod.
I will start with outer coil today along with cw,ccw ferrite rod but no support for pvc pipe.Just using the box as shown in video for now.
Hi Mag & all,
The PWM frequency is 21.9KHz. As I previously commented, the pulsing is primarily an interaction between the grenade and inductor coils and only appears when the inductor coil is tuned to resonance, max voltage amplitude across the cap (480 / 490nF). The lamp pulses even without the Kacher powered up. However, when the Kacher is running, the amplitude of the secondary coil voltage does affect the pulse rate. Slight adjustment of the PWM frequency either side of the 'sweet spot', in my case about 21.9KHz provides full control over the pulse frequency. It may be that the onset of lamp pulsing is a convenient indicator as to when the inductor coil hits the 60th harmonic of the grenade coil. As a side issue to this, I have attached a scope shot to show how the waveform (scoped IGBT drain to source) is affected by the Kacher HV oscillations.
Hoppy
Quote from: itsu on November 07, 2014, 03:34:11 AM
Hoppy,
5mm is very long, is that across the whole "tuning range" when using the ferrite or does it peak at a certain frequency?
My Kacher is running at 1.9MHz at 36V / 1A, but produces minimum streamers then of 0.5mm, but when tuning with the
ferrite rod, it peaks around 1.1MHz with 3mm streamers (tuning done via scope probe laying nearby for max. amplitude).
Regards itsu
Itsu,
I have drawn the spark again today a few times and yes, its more like 3mm, possibly 4mm long, so it does appear that mine is no longer than yours.  ;)
The spark length peaks around the frequency I tuned the Kacher - 1.316MHz, same as grenade frequency.
Hoppy
itsu
itsu
All,
here it is presented that the latest Ruslan 24V system works with these value's"
http://www.overunity.com/12736/kapanadze-cousin-dally-free-energy/msg421510/#msg421510
push-pull osc:  34.15KHz
series cap 1.2uF
bifilar coil 18.75m (2 layers Tesla way)
When using an online resonance calculator like:  http://www.1728.org/resfreq.htm
it shows that for reaching 34.15KHz, with a capacitor of 1.2uF the inductance of the bifilar coil needs to be 18.26uH
This is very low as i measured my 3 layers bifilar coil to be 246uF (18.75m)
Now that i have 2 layers, so about 12m, it still measures 111uH.
With 1.2uF it will resonate at 13KHz which is far away from the mentioned 34.15KHz
Questions:
Do we know if the new setup really resonates at 34KHz?
Do we know if the new setup really uses 1.2uF capacitor?
Does this mean that the 18.75m (or less) bifilar coil has an inductance of only 18uH?
If so, how does one get such a low inductance with a 18.75m 2 layers coil? (bifilar way, but in opposite directions?)
Regards itsu
Hoppy
Quote from: itsu on November 07, 2014, 05:08:50 AM
Voltage is around 1KV and current drawn by Kacher at tuned frequency is 0.68A. The voltage figure is not reliable as my HV probe (home made) is loading the secondary too much.
Hoppy
