0 Members and 2007 Guests are viewing this topic.
skywalker66
Hopy,
Ruslan showed in one of his videos hand- draw schematic which I attached.
URFA experimented with this schematic and get that intriguing effect.
Hoppy
Quote from: skywalker66 on November 07, 2014, 06:12:19 AM
Hopy,
Yes, this is the hand-drawn schematic I based my build on and is the only one from him to my knowledge. I differentiate between a circuit diagram and a circuit schematic.  ;)
It may be that more capacitance is needed once a proper earthing system is established, which might account for why Ruslan shows paralleled 0.47uF caps in his videos??
skywalker66
Quote from: Hoppy on November 07, 2014, 06:19:46 AM
It is more like a combination of series-parallel caps (0.47 series with a group of 0.47||0.22||0.1 or so), look closely picture attached. Equivalent capacitance will be near 0.3uf.
Hoppy
Quote from: skywalker66 on November 07, 2014, 06:35:54 AM
Yes, you are right! - good eyeballing.  :)
magpwr
Quote from: Hoppy on November 07, 2014, 04:48:59 AM
Hi Mag & all,
The PWM frequency is 21.9KHz. As I previously commented, the pulsing is primarily an interaction between the grenade and inductor coils and only appears when the inductor coil is tuned to resonance, max voltage amplitude across the cap (480 / 490nF). The lamp pulses even without the Kacher powered up. However, when the Kacher is running, the amplitude of the secondary coil voltage does affect the pulse rate. Slight adjustment of the PWM frequency either side of the 'sweet spot', in my case about 21.9KHz provides full control over the pulse frequency. It may be that the onset of lamp pulsing is a convenient indicator as to when the inductor coil hits the 60th harmonic of the grenade coil. As a side issue to this, I have attached a scope shot to show how the waveform (scoped IGBT drain to source) is affected by the Kacher HV oscillations.
hi Hoppy,
Thanks for the reply Hoppy.This is getting interesting Hoppy.
I have verified that to get this pulsing effect you were indeed using 60th Sub-harmonics of 1.316Mhz.
I just entered 1316000 hz into the excel harmonics calculator at the sub-harmonics section and i got 21.933khz at the 60th sub-harmonics which tallied with your pwm generator.Nice...... :D
This is important piece of verification for me or for us since i am about to start assembling the antenna later which is combined with my wireless 60th sub-harmonics generator which is sync with kacher.
It's just 7:40pm here i just woke from my 1 hour cat nap to give me energy for the rest of the night till 1am.
I have previously mentioned about the 1/2 wave at 100th or 120th sub-harmonics which will be around 12khz...15khz which the L/C resonance of the 25 turns with 1uf or 1.2uf will fall within that range.
I understand without the L/C resonance eg 470nf at around 22khz the kapanadze coil won't even light a bulb.
If you recall URFA played with kacher in order to light the bulb without it bulb won't even stay lit for long. or even power on.
Although i am unable to co-related to the old Akula device.I know he was using around 0.8uf...1.8uf 2000volts  microwave capacitor in the past from the 3 turns.Just take a look at the common range of microwave capacitor value.
