0 Members and 2007 Guests are viewing this topic.
skywalker66
So, until now we can conclude that Ruslan tried combinations of caps till get a series resonance frequeny which match 50-th subharmonic of kacer.
magpwr
Quote from: skywalker66 on November 07, 2014, 06:35:54 AM
It is more like a combination of series-parallel caps (0.47 series with a group of 0.47||0.22||0.1 or so), look closely picture attached. Equivalent capacitance will be near 0.3uf.
hi skywallker66,
If you connected 4 capacitor in parallel the uf value actually increases.
Please don't be confuse with "RESISTOR" if you combine 4 resistor in parallel only then it's resistive value will be lowered.
That piece of picture from video was already reverse engineered by me to derive estimate value at  (0.47uf+0.47uf)+0.22uf+0.1uf.To get around 1.3uf which tallies with the circuit diagram at 1.2uf.
;D
Hoppy
Quote from: skywalker66 on November 07, 2014, 06:52:03 AM
Don't you mean 60th harmonic? Kacher and Grernade are matched.
T-1000
Quote from: itsu on November 07, 2014, 05:10:02 AM
Questions:
Do we know if the new setup really resonates at 34KHz?
Do we know if the new setup really uses 1.2uF capacitor?
Does this mean that the 18.75m (or less) bifilar coil has an inductance of only 18uH?
If so, how does one get such a low inductance with a 18.75m 2 layers coil? (bifilar way, but in opposite directions?)
Regards itsu
To answer your questions you need to get starting points first:
1) The frequency grenade coil is resonating with ground connected and BEMF (Tesla coil or similar source) oscillations are picked up from antenna. (the the signal source should have ground isolated by diode and earth is negative side)
2) The frequency ratio between signal source and grenade coil resonance (should be 1/3rd as Ruslan mentioned)
3) The induction heater circuit frequency ratio to grenade coil (1/50th, 1/60th and down to 1/100th with division step 2)
When you have numbers for the list above your questions will have answers :)
skywalker66
Quote from: Hoppy on November 07, 2014, 06:58:33 AM
No, according his last video. Ruslan showed 1.736MHz for Kacer and 34.15KHz for push-pull, and he mentioned something about 50th subharmonic in that video . Now you can do the math for yourself.
