0 Members and 117 Guests are viewing this topic.
T-1000
Quote from: skywalker66 on November 07, 2014, 07:59:26 AM
Hi T-1000
That part quite confuse me for some time. According that statement grenade coil self-resonance frequency must be 3 time kacer's frequency, or I'm wrong ? Can you elaborate a little on this issue ? giving a hypothetical example ?
Lets say the full resonant wave length with earth ground attached is getting to 65.172 meters which is 4.6MHz. The grenade coil maximum peak will be on 1/4th frequency which is 1.2MHz (to make energy potential wave nodes difference on the wire ends).
Ruslan is saying we need 1/3rd which is 1.5333MHz - the way I see a bit out of sync... And 1.533MHz for maximum peak on Tesla coil need to be 1/4 of full wave length for Tesla coil secondary as per Tesla coil calculations. So the wavelength is 1.5333MHz / 4 = 0.38333MHz and is 195.52 meters maximum for secondary Tesla coil secondary resonance which is can be a frequency on primary coil to excite Tesla coil.
Excuse me if it involves quite long math just this is way I am calculating approximate frequencies when making Tesla coils and also after calculation the resulting frequency multiplied by 0.75 is approximate to real frequency aim for...
Hoppy
Quote from: skywalker66 on November 07, 2014, 08:25:12 AM
Oh, boy ! You mess things.   ???
Those values is just particular for Ruslan's setup, that don't mean they work for you, unless you remade your grenade to have self-resonance frequency to that particular freq. (1.736MHz). But not that is the point, does it?
Doh - good and obvious point. I obviously need to rest my brain!
MenofFather
Quote from: itsu on November 07, 2014, 05:10:02 AM
All,
here it is presented that the latest Ruslan 24V system works with these value's"
http://www.overunity.com/12736/kapanadze-cousin-dally-free-energy/msg421510/#msg421510
push-pull osc:  34.15KHz
series cap 1.2uF
bifilar coil 18.75m (2 layers Tesla way)
When using an online resonance calculator like:  http://www.1728.org/resfreq.htm
it shows that for reaching 34.15KHz, with a capacitor of 1.2uF the inductance of the bifilar coil needs to be 18.26uH
This is very low as i measured my 3 layers bifilar coil to be 246uF (18.75m)
Now that i have 2 layers, so about 12m, it still measures 111uH.
With 1.2uF it will resonate at 13KHz which is far away from the mentioned 34.15KHz
Questions:
Do we know if the new setup really resonates at 34KHz?
Ruslan say, that it resonate on 32 kiloherc (then divice selfrun).
QuoteDo we know if the new setup really uses 1.2uF capacitor?
We do not known that he use capasitor in 24 V system. He about it nothing say.
QuoteDoes this mean that the 18.75m (or less) bifilar coil has an inductance of only 18uH?
No. I think, Ruslan not have 18 meters. I think, he have 11 meters like in 12 volts system.
magpwr
Quote from: Hoppy on November 07, 2014, 08:12:30 AM
OK, I set-up the Kacher to 1.736MHz and PWM to 34.15KHz and tried a lot of cap values around 0.3uF in series with the inductor and strangely could get no appreciable voltage across the cap and had to scope down to about 5V/div to see a waveform! A far cry from what I get at the 60th harmonic.
hi Hoppy,
***This is gonna be interesting news for us at multiple level for today at least***********
I have added a outer antenna to my 25 turns bilfilar coil along with cw,ccw ferrite rod.
Make it even more interesting i noticed at resonance which is tuned via small ferrite rod in kacher.
Yes i have spotted the same pulsing on the bulb too at 60th sub-harmonics. :D :D :D
Next section-
To make it even more interesting there is tiny current flow to the earth at resonance which my multimeter is set to 10Amp range A/C detected in mA around 16mA to 20mA.
Take note this is important the probe negative to be connected to same earth/ground connection and it's connected to capacitor after 3 turns.
There is various banding present within the same frequency at the capacitor.
My kacher is running at 776khz once the antenna is connected which is bad news.(I will need to tune my kacher coil to operate at higher frequency which means i will need to remove half of the windings at least or little more than half since i can use ferrite rod to tune kacher oscillating frequency easily.Pending task for tomorrow.)
Now this is interesting part at 60th sub-harmonics of 776khz the frequency of my 60th-sub harmonics PWM generator would be running at 12.933khz.
But on scope it shows as 14.5khz across capacitor 1uf  with bulb pulsing.If i remove earth this won't work.
(Honestly i don't know how this frequency appear out of no where although L/C of my 25x2 turns 124.5uH with 1.0x uf would be at this frequency 14.5khz)
This is the required spec needed for my setup
6.64785Mhz  (Optimal frequency of fully assembled multilayer kapanadze coil with 25 turns bifilar winding.Careful tuning also reveal at this frequency it starts to constantly vibrate to higher voltage in mV better than than the rest of the frequency which is already at optimal resonance)
6.64785/4=
1.661962Mhz (My kacher frequency to be oscillating at with antenna attached)
60th sub-harmonics version-
27.699khz (60th sub-harmonics PWM generator)
13.849khz (120th sub-harmonics.Capacitor value selection base on-LC resonance of "capacitor" and 25 turns x 2 bifilar at 3 turns)
50th sub-harmonics version-
33.239khz (50th sub-harmonics PWM generator.*Ruslan version)
16.619khz (100th sub-harmonics.Capacitor selection-LC resonance of "capacitor" and 25 turns x 2 bifilar at 3 turns)
URFA
Hi all.
I would like to share schema of my setup. I am still working on this schema. I have effect of the ground now in my experiments.  But when my power supply connected to the network effect is bigger. And when I use battery,the effect of the ground verry little. Now I am using 220v inverter for my power supply(The batteries are connected to the inverter) and effect not bad but not enough. I am sure the hand- draw schematic of Ruslan correct But    there are missing  area.
Yours Ibrahim.
