magpwr
Quote from: URFA on November 07, 2014, 09:09:28 AM
Hi all.
I would like to share schema of my setup. I am still working on this schema. I have effect of the ground now in my experiments.  But when my power supply connected to the network effect is bigger. And when I use battery,the effect of the ground verry little. Now I am using 220v inverter for my power supply(The batteries are connected to the inverter) and effect not bad but not enough. I am sure the hand- draw schematic of Ruslan correct But    there are missing  area.
Yours Ibrahim.
hi URFA,
May i ask you few question for now.
1)Are you using around 1.2uf capacitor after the 3 turns.
2)I have noticed the bottom of multilayer and top of 25 turns needs to be connected to earth.Is this your version if so i will use your version? Thanks.
The Ruslan version is top of  multilayer and top of 25 turns is connected to earth which i am currently using and i have no idea which is right.
Thanks for providing updates.
skywalker66
Quote from: T-1000 on November 07, 2014, 08:31:59 AM
Lets say the full resonant wave length with earth ground attached is getting to 65.172 meters which is 4.6MHz. The grenade coil maximum peak will be on 1/4th frequency which is 1.2MHz (to make energy potential wave nodes difference on the wire ends).
Ruslan is saying we need 1/3rd which is 1.5333MHz - the way I see a bit out of sync... And 1.533MHz for maximum peak on Tesla coil need to be 1/4 of full wave length for Tesla coil secondary as per Tesla coil calculations. So the wavelength is 1.5333MHz / 4 = 0.38333MHz and is 195.52 meters maximum for secondary Tesla coil secondary resonance which is can be a frequency on primary coil to excite Tesla coil.
Excuse me if it involves quite long math just this is way I am calculating approximate frequencies when making Tesla coils and also after calculation the resulting frequency multiplied by 0.75 is approximate to real frequency aim for...
T-1000 thanks for your explication, but now my confusion in bigger... :-\
Sorry for that. It will take some time to digest that.
Jeg
Hi all.
Yours Ibrahim.
Thanks a lot Urfa for mentioning those points! Point A is the output of the dower supply of 24V?
Hoppy
Hi all.
Yours Ibrahim.
Hi Urfa,
I'm getting the effect with the 24V supply connected on either side of choke. However, I have not yet got an earth wire connected as you have, so this may be the reason.
Jeg
Quote from: Hoppy on November 07, 2014, 09:51:40 AM
Hi Urfa,
Hoppy, at the output before the 10uF cap, you have a one diode or a bridge?
Tnks
