T-1000
Quote from: Void on November 07, 2014, 10:44:32 AM
Here's a new post from Ruslan yesterday on realstrannik explaining more about how he thinks these devices work,
and how to approach configuration. IMO, it wouldn't hurt to keep your grains of salt handy. ;)
We are back to talking about "NMR" again it appears. :)
http://www.realstrannik.ru/forum/39-kapanadze/134930-ustanovka-ruslana-kulabuxova.html?start=3582#247894
"topruslan
Ко всему прочему , добавлю следующее :
1.Качер лучше отвязать по питанию с обоих питающих выводов + и -
2.Лучше использовать полевой транзистор IRF460 (необходимо поставить стабилитрон в затворе транзистора. А лучше 2 встречно включенных)
Полевик лучше будет работать. Доказали эксперименты :blink:
For anything else I am adding following:
1) It is better to isolate Katcher from power (noise filters on + and +)
2) It is better to use MOSFET IRF460 (need to put stabilitrons on gate of transistor. And betetr with 2 connected opposite)
The MOSFET will work better. Proven by experiments :blink:
"topruslan
Катушка Тесла должна располагаться на той же трубе что и биф.
Частота должна быть настроена на резонанс меди.
The Tesla coil have to be on same tube as bifilar.
The frequency of Tesla coil must be tuned to resonant frequency of copper.
Частота ЯМР в обоих природных изотопах меди.
The frequency in both natural isotopes of copper
Isotope Spin Natural
abundance(%) Quadrupole moment
(10-30m2) Relative
sensitivity Absolute
sensitivity NMR frequency (MHz)
at a field of 2.3488T Reference
sample
Cu-63 3/2 69.09 -22.0 9.31E-2 6.43E-2 -26.505 [Cu(CH3CN)4][ClO4]
Cu-65 3/2 30.91 -20.4 0.11 3.52E-2 -28.394
Hoppy
Quote from: John.K1 on November 07, 2014, 12:53:09 PM
Hi Hoppy,
Y
Guys,  I have put the ferrite with couple turns of wire between the Tesla and Granade. I do not see any function of it. Does it work for you??
Neither do I John.
Void
Void
Your point no.2  I do not understand what that means, but you sai there to use Mosfet 460, but on his skype conference he doesn't recommend them . He recommends some 7310 , IRF 260.  "Poleviky"  are  Fety  (Pole - field)
Hi John. That is just an English translation of what Ruslan wrote in the realstrannik forum recently.
Maybe it was a typing mistake by Ruslan and he really meant to type IRF260? That I don't know...
The Russian text was as follows:
"Ко всему прочему , добавлю следующее :
Полевик лучше будет работать. Доказали эксперименты :blink:"
All the best...
MenofFather
Quote from: John.K1 on November 07, 2014, 12:14:20 PM
Guys,
Just thinking about the bulb test  ( bulb connected to the first output of the grenade coil and the second  end of the bulb free)
Why if I touch the insulated wire right before the bulb - NO light.
Why if I touch the insulated wire of the free end - MORE light
Why if I ground the free wire side - NO light
Why if I connect free end to three turns on the ferrite yoke - MORE light
Why if I connect free end to three turns and Ground on 12 turns coil on the ferrite yoke - even MORE light (such a small electron trap of Barbosa and Leal? :D )
Why if I connect free end to 12 turns on the ferrite yoke, no ground - NO light.
Answer? Resistance of load- capacitance - Inductance -  Maybe I will say a nonsense but is it impedance from our grenade we need to match for  best performance?
Thanks,
I not all understand. But seems kacher changing push pul generator frenquency and that gose from LC resonance on inductor or no and change lamp brighnes.
If I not use ground my kacher also wery strong changing push pul frenquency, if I use short ground then influence from kacher to push pull generator is over. Then I use long very ground and winded, then influence from kacher to push pull generator frenquency apears again.
Void
Quote from: T-1000 on November 07, 2014, 12:57:03 PM
1) It is better to isolate Katcher from power (noise filters on + and -)
Thanks T-1000!
All the best...
