0 Members and 704 Guests are viewing this topic.
Void
Quote from: magpwr on November 07, 2014, 05:33:35 PM
hi Void,
You are "Counter productive" to this topic.
May i ask what is your progress can you show us photo your version please.
If you have not started even building one then please stop creating confusion by picking on every words i say.
Here we go again... ;)
Void
Quote from: Jeg on November 07, 2014, 04:27:53 PM
If we consider radiator as a pole of a cap, radiation passes at zero voltage crossing to the other coils. It just confuses me the fact that they both go to ground.
Hi Jeg. Can you explain what you mean when you say 'the radiation passes at zero voltage crossing to the other coils'?
All the best...
Jeg
Quote from: Void on November 07, 2014, 05:58:50 PM
All the best...
Read here pls. at zero point energy paragraph..
http://www.nuenergy.org/nikola-tesla-radiant-energy-system/
Enjoykin
Only for IBRAHIM CICEK !!  :)
Hello my Persian frined !! :)
Excellent results !! I have glad you made it. You have almost catched OU-Radiant effect !! About 95% your Radiant charge pump from ground work for sure !! There are two things you should try.
You should Ground 6th layer on grenade not 1st. On Ruslan block diagram is mistake. Also small light bulb 20watts should shine very bright on frequency coincidence without grounding. Swap grounding points. Use two accumulators 12V/7Ah for power generator - not power grid. Make experiments with different grounding wire lenght ( make hunk of grounding cable - twist one turn by one turn) try get better output power. Use up to 500 Watts light bulbs. Also make groudning from Litz wire making it from many insulated small diameter conductors. Akula is using Litz for one of his generator grounding.
Ruslan's  thought - you have problem with output power. (maybe winding directions of grenade and ground point swapped). Look this picture. There are several interesting ideas of Ruslan with my comments for you. Ruslan will present his working schematic but not soon because he is experimenting a lot od different configuartions trying extract more than 5KW power from Grenade coil. I am working on new type of PLL circuit with extremelly small phase error. If you want try i suggest try this Akula PLL for his 1.5KWt generator. It is a part of his receiver TT. I have only changed working PLL coefficients. You can make free experimenting with different RC time constants in phase-shift stages.
I think you will first get Free Energy to Persia. I wish you Luck and Good Success.  :)
Reg.
Enjoykin !! :)
УСПЕХОВ !!!!
Void
Quote from: Jeg on November 07, 2014, 06:08:55 PM
Hi Jeg. Ah, Ok. You were talking about zero point energy it seems. I thought maybe you were referring to
to zero crossings of sinewaves in the inductor and grenade coil, or something along those lines. :)
All the best...
