0 Members and 699 Guests are viewing this topic.
magpwr
Quote from: Hoppy on November 08, 2014, 03:02:00 PM
Hi Enjoykin,
Please explain the meaning of the caption about nano-pulse current source as shown in the attached clip of the circuit schematic you posted.
hi Hoppy,
Thanks for highlighting about copper strip.This helps me to recall of a experiment which was conducted in Russia using long strip which there was 0.5mm to 1mm gap given to achieve lighting a bulb in the aluminum covered box which was provided from a HV source.
I have just wound a copper strip and ensure i give 0.5mm to no more than 1mm gap in between.Fyi only -URFA is using 4 turns.
This copper strip "counter" to the secondary coil winding.
I have attached photo of this strip which i just completed.
"This is the primary reason why i love to read all sort of comment.It helps me to recall almost anything"
John.K1
Well,
I didn't move more far yet from last time.  I have made basic tuning to grounded 1.87MHz, to get my 220V 25W light bulb ON.  I just got my IR2153 which I am going to use for my Push-pull I will make today.
I am not good in electronics yet, but can somebody tell me why do I see so "Many parts"  designs for push-Pull? Can I just connect my small of-shelf 555  based oscillator via Schmitt trigger opto-couples?
MagPwr- that's stripes are in opposite direction -right? Could it be made from Aluminium foil? :)
The ferrite bar- as you can see on the picture below I put just some turns of wire.  What effect we are expecting? How to tune it if we do not know what to expect?  Ruslan said About Akula he was using it to tune the frequency (yes or not? ) . I do no see any effect on frequency myself. Maybe I have something wrong. Ruslan also said about this ferrite bar -(freely translated :) ) - " It will be a pain in an ass, but you will need to work on it. There can be 5,6 maybe 8 turns...."    So, do we need to put as much of turns as it will start to influence the frequency or what ever other effects?? Probably the best way to see if it works is to see it on brightness of the bulb?
I was reading some build tips about Tesla coil, If I right understand the most optimal or efficient is "square design" - the length of coil as its diameter. Latter I will experiment with bigger diameter. Also, as my frequency is below 2MHz- the current runs in around 0.047mm skin depth- why is Ruslan using quite heavy wire? ( I use Ø0.31)
Thanks
MenofFather
"I am not good in electronics yet, but can somebody tell me why do I see so "Many parts"  designs for push-Pull? Can I just connect my small of-shelf 555  based oscillator via Schmitt trigger opto-couples? "
555 not have two chanels.
John.K1
Hi MenofFather- so how does it work? Signal to one Fet and then To other?  I have made a signal divider time ago using CD42...  Would that work??
Thanks
MenofFather
Quote from: John.K1 on November 09, 2014, 03:16:59 AM
Yes.
I think, better just wound with 0.4-0.9 mm diameter cuper wire. And you must search resnance on 1.5-1.7 megaherc.
