0 Members and 630 Guests are viewing this topic.
MenofFather
Quote from: John.K1 on November 09, 2014, 03:29:00 AM
Hi MenofFather- so how does it work? Signal to one Fet and then To other?  I have made a signal divider time ago using CD42...  Would that work??
Thanks
If you using 555, then you need use with one mosfet. TL494 puting signal to one mosfet, then to other. 2153 also.
John.K1
Hi MenofFather - I have may Tesla nicely tuned to 1.87MHz with the ground connected - I think this is the basic I have successfully done. Now only that Push-Pull bother me :)
John.K1
MenofFathe- Thank, it means my CD4022  devider will work. In the input will be my 555 signal and divider divide this signal between as many Mosfets as I want (8 is max - one by one clean signals)
My point is if I use the of shelf 555 timer I can nicely tune frequency and duty cycle.
Thanks,
Jeg
Hey guys :)
I decided to stop the magnetic influence between my Tesla coil and grenade because they are close together and I don't like to have many unknown variables like this side influence. What is the better way to cut it's magnetic influence? I guess some turns at the top of Tesla on the other direction than the main coil...
And something else in relation with this magical ferrite choke between Tesla and radiator.
Lets say that your grenade is tuned to i.e 2Mhz. A half cycle of 2Mhz lasts 0.25us. If I shoot it with a nano-pulse, in what base you believe that grenade will respond in a faster time than the above? What ever narrow pulse I will fire it, grenade will respond at a certain rise time and fall time. No less! So this nanopulse ferrite choke thing is just a myth. I hope you see it too.
T-1000
Quote from: Jeg on November 09, 2014, 04:05:30 AM
Hey guys :)
Increase the distance between grenade coil and Tesla coil... ;) In akula/Ruslan setup they are on quite range aside.
