0 Members and 712 Guests are viewing this topic.
Void
Quote from: d3x0r on November 08, 2014, 10:40:25 PM
Theoretically it should?  the self inductance from the start of current flow in the one end should make current flow complimentarily in the other end.... but it takes times of domains in the ferrite to flip?  maybe I don't have a long enough delay line in mine?  (it's kinda a short bar)
Hi d3x0r. I really don't know how it should work, or if it really does work as claimed at all.  I think it's good to try to
understand conceptually how various things might be working, but the way I look at it is that it is all just ideas however
until we can demonstrate a given concept practically in an actual circuit, and show clearly how the concept applies in actual
changes in working functionality in a circuit.
All the best...
a.king21
Quote from: Hoppy on November 09, 2014, 10:41:16 AM
Nick,
My circuit is currently working as an inefficient inverter, so the main earth presumably adds the magic touch, assuming that we are not lacking an important piece of the circuitry.
Your comment about the induction circuit output needing to be superimposed by a DC voltage from the Kacher is interesting. Where did you get this info from?
Benitez said that you get ou by mixing high frequency spikes with ordinary electricity.  He also said that this output is increased if the spike generator is in resonance. Hope this helps.
Void
Quote from: NickZ on November 09, 2014, 09:43:22 AM
NOTE: I did notice a difference when the ferrite rod with the two small opposite wound coils are used. The kacher's output becomes more intense, RF burns , when previously no RF burns were felt. I would say that the voltage drops, but  the amperage is raised, and of course this changes the running frequency of the Kacher, at the antenna.  Just thought that I'd mention that, again, as some of you don't seam to be noticing much difference from the ferrite rod tuner coils.
However the bulb brightness only improved slightly in my case, when connecting through the ferrite rod.  But, noticeably.
It would also be good to know just how and where to connect the 3 fans, to the circuit's input. Be it to 12v, or 24v circuits.
Hi Nick. From my own testing so far with this, what you may be seeing in regards to the output of the kacher seeming
to burn more with the ferrite rod with its opposing windings in place on the output of the kacher, is that adding
this rod and windings in place will probably lower the frequency of your kacher/tesla coil at least somewhat. Different frequencies
will tend to produce different types of corona discharge with different characteristics. In some cases the differences
may be very minor, but in other cases it can be quite a noticeable difference. I am still experimenting with this myself as well.
There may well be other effects introduced by this ferrite rod with opposing windings, but I think it may help
to keep in mind that Ruslan's 12V device did not include this piece and it apparently was still working well, from what could
be gathered from the videos anyway. Ruslan apparently decided to replicate Akula's second self runner much more closely with
his 24V device, so he added the ferrite rod and opposing windings, but I have to wonder how much effect/improvement it
really has. Ruslan was previously translated as saying that you may or may not need this ferrite rod to get things working.
Regarding the fans, you should be able to just connect them to the output of the power supply which loops the
output back to the input. If you have a 12V power supply, use 12V fans. If you are using 24V, then use 24V fans.
All the best...
Jeg
Every bit of info is valuable king21. Everything points at the same method.
I started few hours ago to build a new Katcher coil, and I still can't tune it at 1Mhz. I put or extract turns, but frequency seems to jump from 980Khz to 1.2Mhz. I put few turns more and then again at 980Khz. Really strange. My previous coil tuned in 10 mins!
Hoppy
Quote from: Jeg on November 09, 2014, 11:47:01 AM
Jeg,
I have found that as I approach the grenade coil 1/4 wave resonant frequency, my kacher frequency will jump between two frequencies much like yours is doing, with one of these frequencies tending to lock-on, which is the one I tune to.
