0 Members and 718 Guests are viewing this topic.
Hoppy
Quote from: a.king21 on November 09, 2014, 11:32:15 AM
Benitez said that you get ou by mixing high frequency spikes with ordinary electricity.  He also said that this output is increased if the spike generator is in resonance. Hope this helps.
Does Benitez define what he means by 'ordinary electricity'?
John.K1
Well guys,
I just started to draw my Push Pull and the first what I noticed is the negative terminal on the Drain of the Mosfet. To make it more confused Enjoyiking supplied some schematic with the N-channel Mosfets (ground on drain??)  and Ruslan's original drawing seen in his YouTube video has drawn P-Channel mosfet but with N-channel type number. What the heck??
Ok , lets, believe it is N-channel- should ground be on the drain as on the picture??
Thanks.
NickZ
  Hoppy:
  I can't remember just where it was mentioned that the superimposition should be DC from the HV pulser, to the magnetic induction coils (12,12, or 25,25, turns).
   Maybe T-1000 knows, or remembers. In some of the older videos, perhaps.
  I tried a UF diode on the end of kacher secondary and got a positive improvement on the bulb brightness, but that was a while back, and I don't remember all the details.  Maybe just give it a try, and see what happens.
  I don't go by voltage/current/or frequencies levels, as most of you are doing.
  I tune my circuits by bulbs brightness levels, instead.
As I don't have, nor really want, all the gear to be able to go that route.
  I'm interested in hearing about how Ursa describes his no-scope tuning methods, as well.
I'm sure that TK had no such instruments, or knew how to even use them correctly. As he had not mentioned anything related to the use of expensive test gear, to build any of his devices.
  I feel that we need to focus on building up exact coil replications, with the proper coil wire specs, using the right opposing (cancelling) field effect, and using properly tuned earth grounds lines, etz... Like Ruslan has shown when replicated the Akula devices, in his own way.
Providing for a tuned ambient energy receiver?
Or,  for a nuclear decay device, instead?
   I'm sure that Wesley would be up for it, if the device is a nuke,  as nuclear seams to be his cup of tea.  Not mine, though...
  Just kidding Wes...
MenofFather
Itsu or others, ifyou want, you can try new schematic.
This schematic works without ground and it selfrunning. Maybe about 10-50 W power output.
http://realstrannik.com/media/kunena/attachments/234/btg3.2.png
What writen in green is 50 Herc resonance. That in blue, that LC circuit must be on 470 kiloherc resonance.
Pusch pull for 50 herc can be any and for 470 kiloherc (higher frenquency also can be and it better) generator also can be any.Transistors for low frenquency (but it can be and not 50 herc, can be and maybe 4 kiloherc) can be IRFZ44n. For hight frenquency IRF640N.TLC is wounded on ferite core. C11 not is, here mistake. Diode D1 is fife diodes in parralel, but inaft can be and with 3. C10 must be chosen for resonance 400-500 kiloherc. If you interest thisschematic, then I give you more details and answer to your questions if you have them.
a.king21
Quote from: Hoppy on November 09, 2014, 12:29:40 PM
He means DC.  12 volts  up to 48 volts approx, which is the level of his patents - although he says it will work at higher DC.
I assume this also works for AC.
The situation Benitez envisages will create a beat frequency.
You get an irregular beat frequency by simple mixing, but you get a better result by resonance.
(Benitez new nothing about beat frequencies)
Both are ou according to Benitez.
