0 Members and 73 Guests are viewing this topic.
Hoppy
Quote from: NickZ on November 09, 2014, 01:46:29 PM
  Hoppy:
  I can't remember just where it was mentioned that the superimposition should be DC from the HV pulser, to the magnetic induction coils (12,12, or 25,25, turns).
   Maybe T-1000 knows, or remembers. In some of the older videos, perhaps.
  I tried a UF diode on the end of kacher secondary and got a positive improvement on the bulb brightness, but that was a while back, and I don't remember all the details.  Maybe just give it a try, and see what happens.
  I don't go by voltage/current/or frequencies levels, as most of you are doing.
  I tune my circuits by bulbs brightness levels, instead.
As I don't have, nor really want, all the gear to be able to go that route.
  I'm interested in hearing about how Ursa describes his no-scope tuning methods, as well.
I'm sure that TK had no such instruments, or knew how to even use them correctly. As he had not mentioned anything related to the use of expensive test gear, to build any of his devices.
  I feel that we need to focus on building up exact coil replications, with the proper coil wire specs, using the right opposing (cancelling) field effect, and using properly tuned earth grounds lines, etz... Like Ruslan has shown when replicated the Akula devices, in his own way.
Providing for a tuned ambient energy receiver?
Or,  for a nuclear decay device, instead?
   I'm sure that Wesley would be up for it, if the device is a nuke,  as nuclear seams to be his cup of tea.  Not mine, though...
  Just kidding Wes...
Thanks for your reply.
Improvements in bulb brightness by tweaking the inverter is neither here or there IMO when the objective is to self-run by removing the power supply. As I commented earlier, we most likely have missing information, coupled with a degree of deliberate misinformation in respect of the information so far given.
John.K1
NickZ
I think we over-thinking this device.  Imagine Russlan with just  ONE year experience  was able to replicate it and as he says - forget about LC resonances (by his mean here is only one on the TV choke :)  )  and forget finding frequencies with SG  and analyzers.
So how hard it can be??
:D
Void
Quote from: John.K1 on November 09, 2014, 01:38:33 PM
Well guys,
I just started to draw my Push Pull and the first what I noticed is the negative terminal on the Drain of the Mosfet. To make it more confused Enjoyiking supplied some schematic with the N-channel Mosfets (ground on drain??)  and Ruslan's original drawing seen in his YouTube video has drawn P-Channel mosfet but with N-channel type number. What the heck??
Ok , lets, believe it is N-channel- should ground be on the drain as on the picture??
Thanks.
Hi John. Likely just drawing errors. Ruslan said he was using IRFP260 MOSFETs, so N-channel, Drain to V+,
Source to ground.
All the best...
NickZ
 Meno:
  Are there any videos of this device, working, or some pictures?
MenofFather
Quote from: NickZ on November 09, 2014, 02:36:23 PM
Meno:
No pictures, no video.
