0 Members and 42 Guests are viewing this topic.
Void
Quote from: John.K1 on November 09, 2014, 03:40:28 PM
Standard wire bulb 220V 20W  (from microwave oven) - one lead connection other end free. This is a basic test of working the granade coil before you continue with other parts like push-pull etc.
The beauty of dielectricity :)
Hi John. Thanks. Just went back and reviewed that picture of yours. Yes the filament is glowing a little bit.
I can't tell from that picture how long the alligator clip lead is that is open circuit at the other end.
How long was this alligator clip lead which is connected to the light bulb, but not connected at the other end?
All the best...
John.K1
Quote from: Void on November 09, 2014, 03:59:16 PM
All the best...
Aligator length +/- 30 cm. Check my  post  :  http://www.overunity.com/12736/kapanadze-cousin-dally-free-energy/6555/#.VF_W3vmsUs8
Many questions there :)
NickZ
  The incandescent bulbs will not light on just the induction from the output coil, with out an earth ground, or some type of virtual ground, like the wire of a certain size. At least as far as I've seen.
John.K1
Quote from: NickZ on November 09, 2014, 04:06:08 PM
With straight grounding of the free end you kill the effect.  Check the post above.
Void
Quote from: John.K1 on November 09, 2014, 03:57:12 PM
Sorry guys I am bothering you again with the push - pull but, should I suppress BEMF of the coils   I am thinking to put between central tap and both other end of the coils some diode. Also between the Gate and the Source 10Kohm resistor and small neon to give it some protection.   Isn't it in some way contra-productive to the functionality of that device?
Hi John. People are using snubber circuits to reduce the back spikes and ringing.
You can maybe check with Itsu or Hoppy to see what they are using, although I think they
may have posted that info already in this thread a while back.
All the best...
