0 Members and 275 Guests are viewing this topic.
skywalker66
Another interesting facts:
One of our rusian friend (I don't remember now which one) translated that Ruslan said he no relate his coils in turns but in meters...Let see how that is related to facts.
1. We know main grenade coil has 37.5m (more or less)
2. MenoFather translate in one of his previous post about  last 2KW device of Ruslan:
Reply #5996 :
Kacher secondary wound in last video 0.8-0.81 diameter wire 9 cm lengh on 5 cm diameter tube. And then to oposite direction with ticker wire little .
Lets assume that info correct, will calculate approximate length of Ruslans kacer:
      turn length on 5cm diameter pipe is about 16cm.
      number of 0.8mm turns fits in 9cm length of coil: 90/0.8 =  112.5 turns
      total length of kacer wire: turn length x no turns = 16 cm x 112.5 = 1800cm = 18m (more or less) which is very close of 18.75 (half of grenade)
3. About inductor length, it is nor 18.75m (1/2 grenade), nor 12.5 (1/3 grenade), but 9.375m (1/4 grenade) - I check myself and 9.375m fit nicely in 2 layer over grenade and display exactly proportions as in 2kw Ruslan's grenade.
Resuming all this:
Grenade:  37.5m - resonate at 1/2 wavelength
Kacer:      18m (or better 18.75m) - resonate at 1/4 wavelength as always kacer do
Inductor:   9.375m - I think its length isn't critical.
Any comments on this issue will be welcome.
MenofFather
I in prievious my schematic about 10-50 W FEG made error, so it can not give free energy. Buttom new schematic.
Edit: in that schematic is some errors, if you replicate them, then I will give you schematic with fixed that errors.
skywalker66
Ruslan has removed input filter X, Y type capacitors from his 24V power supply for reason displayed in my earlier post (for complete isolate 220v side of 24V side of power supply).
Edit: If someone have that type of power supply, please check if there are capacitors in place. I suspect there is.
Void
Quote from: MenofFather on November 10, 2014, 06:27:25 AM
Hi Menof. It will be difficult for people to assess this schematic without at least knowing who created
this schematic and where it came from, etc. :) Also, who has tested this circuit to determine that it
is producing over unity? Was this schematic posted to a thread on realstrannik? If so, which thread?
All the best...
NickZ
  Skywalker:
   "About DC HV positive pulse upon induction coils it seems you get it right.
Ruslan use those HV positive pulse too, interposed on induction coils, but he don't put diode on HV side on kacer, but between negative side of kacer and earth ground (cathode of diode on negative of kacer, and anode of diode to earth ground), which made only positive DC pulse on antena related to earth ground. But for that, negative side of kacer neither of push pull must not be connected directly to earth ground, the only one connection between the two is by means of that diode".
        end quote from Skywalker.
  I don't know if that works similarly or the same, as putting the diode on the end of the Kacher secondary output.
Maybe it doesn't matter if the Kacher output is rectified DC, or pulsed AC, as they might both work. Try both ways, and see...
  I also tried placing a diode on the earth ground connection. But, not from the Kacher negative side. Just from the output coil on the grenade, which is also connected by a jumper to the 3 turn coil's impulse capacitor. Don't remember what happened, now.
   The thing is to try different things, to see what helps to increase the output.
  Ruslan's way of putting diode(s) to the earth ground must work better than not doing so,  or he would not have made that new additional change.
Should be followed, I would think...
  Also, Sky you mentioned that:
"Inductor:   9.375m - I think its length isn't critical".
   It can effect the output from that inductor, and will decrease it, if it's too long. Like 18m, or so. This is where the diagrams are not correct, at least that I can see.
  Same thing with the earth ground cable. If it's too short? It can even kill the effect, as some may have already noticed.
