0 Members and 52 Guests are viewing this topic.
Hoppy
Quote from: John.K1 on November 10, 2014, 12:53:37 PM
Skywalker:  In the matter of that length of katcher  you posted above, I believe you need to tune it to your "Grounded" grenade. And the length of the  grounding cable is like an extension of the grenade which means you must adjust number of turns on your katcher - in other words- I believe it is very individual.
This is where we need detailed guidance from Ruslan.
John.K1
Ruslan said we will nedd to add around at least 5-6 or more meters of wire to your katcher to resonate it on the frequency of your granade.
I only realized now what about that inductor? if the length of the grenade actually increase?
MenofFather
Quote from: Void on November 10, 2014, 11:18:52 AM
I am pretty sure
Ruslan could have explained how he does this reasonably clearly if he really wanted to.
Agree.
Quoteif you think it has merit it might be better if you
build the circuit and then you can maybe start a new thread here if you find anything promising with that circuit,
once you have done some testing with it.
But remember, that I can not build this divice never. Or can build not corect, because I not rich and not have many, to bay all needed wires, cores and so on. :)
Void
Quote from: MenofFather on November 10, 2014, 01:12:51 PM
Hi Menof. I didn't know that. Still maybe you can find some surplus cores and transformers
and wire cheap somewhere. Maybe some people here will be willing to work on that other circuit
with you and run some tests. I personally still don't want to give up on the Ruslan
and Akula circuits until I have done a lot more experimenting, unless it is shown that Ruslan
has just been fooling people all this time.  ;D
All the best...
skywalker66
Quote from: Ed morbus on November 10, 2014, 11:22:56 AM
I hope this is the same power supply
Hi Ed !
Thanks for posting photo of your power supply. Not the same but close enough to make a point. Please observe the presence of that 4 blue disk capacitors Y type, 2 just
at the 220V input side, and other 2 or 3 right after the common mode coil. In the Ruslan power supply photo that I'm presented previously those capacitors seems to
missing, maybe removed by purpose for eliminating unwanted ground loops in HF. It's just a personal observation...
I also suspect he may changed his FWR with ultra fast diode.
And of course, that power supply can be replaced with isolated batteries during tests, is even better.
