0 Members and 595 Guests are viewing this topic.
John.K1
Quote from: Hoppy on November 11, 2014, 02:38:26 AM
Why is that necessary John?
Hoppy- To be honest I do not understand myself and to be more honest I didn't put it there yet :) . I have my emitter straight on ground :).  What  Ruslan said about it doesn't give me sense too. I have to listen it again and I will let you know. I only remember he was saying the resistor pass the potential and bla bla bla .
Guys, I am getting strange feeling about that guy. He wasn't able to answer some questions and he directed the question to somewhere else. The Russian side is now full of discussion if is i fake or not.  I hope not :)
URFA
Quote from: Enjoykin on November 07, 2014, 06:34:35 PM
Only for IBRAHIM CICEK !!  :)
Hello my Persian frined !! :)
Excellent results !! I have glad you made it. You have almost catched OU-Radiant effect !! About 95% your Radiant charge pump from ground work for sure !! There are two things you should try.
You should Ground 6th layer on grenade not 1st. On Ruslan block diagram is mistake. Also small light bulb 20watts should shine very bright on frequency coincidence without grounding. Swap grounding points. Use two accumulators 12V/7Ah for power generator - not power grid. Make experiments with different grounding wire lenght ( make hunk of grounding cable - twist one turn by one turn) try get better output power. Use up to 500 Watts light bulbs. Also make groudning from Litz wire making it from many insulated small diameter conductors. Akula is using Litz for one of his generator grounding.
Ruslan's  thought - you have problem with output power. (maybe winding directions of grenade and ground point swapped). Look this picture. There are several interesting ideas of Ruslan with my comments for you. Ruslan will present his working schematic but not soon because he is experimenting a lot od different configuartions trying extract more than 5KW power from Grenade coil. I am working on new type of PLL circuit with extremelly small phase error. If you want try i suggest try this Akula PLL for his 1.5KWt generator. It is a part of his receiver TT. I have only changed working PLL coefficients. You can make free experimenting with different RC time constants in phase-shift stages.
I think you will first get Free Energy to Persia. I wish you Luck and Good Success.  :)
Reg.
Enjoykin !! :)
УСПЕХОВ !!!!
Hello  Enjoykin.
Thank you very much my friend. I'll try your your advice.  I think your PLL circuit better of mine PLL Circuit. I'll try your PLL circuit. I want to share a schema and this scheme gave better results than old schema. I drew this diagram according to the first video of the Ruslan. He did not use 28T on yoke for grenade coil like Akula. He has only use 3 turn on yoke for inductor.(but in the video he used 5-6 turn I think).But I used 28T(on yoke) for grenade coil in the my schema. I think sometimes that This system can work without  ground if done well tuning. To my way of thinking. There was no ground in the first video of Akula.
Best regards.
Ibrahim
Note: I'm not persian. I am Turkish.  :)  ;)
URFA
Quote from: magpwr on November 07, 2014, 09:31:23 AM
hi URFA,
May i ask you few question for now.
1)Are you using around 1.2uf capacitor after the 3 turns.
2)I have noticed the bottom of multilayer and top of 25 turns needs to be connected to earth.Is this your version if so i will use your version? Thanks.
The Ruslan version is top of  multilayer and top of 25 turns is connected to earth which i am currently using and i have no idea which is right.
Thanks for providing updates.
Hi magpwr
Answer to your questions.
1-I used 2.25 uf cap after 3 Turns.
2-I think it is not necessary connected to earth(To my way of thinking ) I don't any different effect when I connect it to ground.
Regards.
URFA
Quote from: Jeg on November 07, 2014, 09:39:34 AM
Thanks a lot Urfa for mentioning those points! Point A is the output of the dower supply of 24V?
Hi Jeg.
Yes.Point A output of the power supply of 24V.
itsu
Quote from: URFA on November 11, 2014, 04:00:11 AM
Hi magpwr
Regards.
URFA,
it shows from your video that these 2 capacitors are in series, so you are using 2 x 4.5uF capacitors in series to get the 2.25 uF?
Thanks,  regards Itsu
