0 Members and 675 Guests are viewing this topic.
Jeg
Quote from: URFA on November 11, 2014, 05:21:41 AM
Yes. You are right. 2x4.5 uf in series.
Thanks a lot Urfa for your kind help. In your drawing I noticed two new things. A cap between grenade and ground, and a disconnected side at your bridge at the output. Is your bridge like that for purpose or you just forgot to draw the missing connection? In addition, is there any diode more between grenade line and ground?
URFA
Quote from: Hoppy on November 11, 2014, 05:46:39 AM
Hi Urfa,
I watched your video with interest. Were you running and lighting your lamps without your power supply connected?
Hi Hoppy.
I still have not tried it. I sometimes think maybe it works After making all connections circuit (for selfrunning)and without connected to the mains power supply to grid. Perhaps this is a secret process  :D  Pehaps the secret of the process needs to be power supply not connected to the main grid or baterry when circuit working. I want to say that After running the device it need to remove the battery, and then the working on self-righting. :D Did anyone try it??
Regards.
skywalker66
Quote from: URFA on November 11, 2014, 05:46:58 AM
Hi skywalker66.
Really I want to describe to you my tuning process but My english is not enough for I can describe it  :(. Let me briefly in shortly explain: For tuning of process I am using pot of the push-pull generator and pot of the kacher and especially the length of the inductor(on granade coil) wire and the length of the TV yoke wire(especially 3Turn on yoke). And I observe the results of changes made. I hope you understand what I say.  :-[
I get it and thanks for trying !  ;)  And don't worry my english is the same, but that don't stop me to try in some degree to communicate.
What can tell about your kacer? What wire length do you use for it (or no. or turns) . Do you have a criteria in choising that length ? Do you had to modify your kacer in order to get the effect?
Regards !
Hoppy
Quote from: URFA on November 11, 2014, 06:04:03 AM
Hi Hoppy.
Regards.
Thanks for your reply Urfa.
Jeg
Quote from: Jeg on November 11, 2014, 05:55:08 AM
Except if this capacitor from grenade to ground is actually a diode. Is there any possibility for that?
