0 Members and 602 Guests are viewing this topic.
Hoppy
Quote from: John.K1 on November 11, 2014, 02:54:35 AM
Hoppy- To be honest I do not understand myself and to be more honest I didn't put it there yet :) . I have my emitter straight on ground :) .  What  Ruslan said about it doesn't give me sense too. I have to listen it again and I will let you know. I only remember he was saying the resistor pass the potential and bla bla bla .
Guys, I am getting strange feeling about that guy. He wasn't able to answer some questions and he directed the question to somewhere else. The Russian side is now full of discussion if is i fake or not.  I hope not :)
Thanks for your reply John. Please keep us up-to-date with the views on the Russian side in respect to the discussions on whether the Ruslan device is faked. On this subject, take a look at his video at the link below between 2:04 and 2:11 minutes. What is he fiddling with under the table. Maybe to check that 'X' wires leading into the component box / mains switched socket box feeding the lamps have not come loose and drooping down into camera view??
http://www.youtube.com/watch?v=X0OWVFIDPf4&list=UU_zn0cdzv_qfsxQUm4e7R9w
Jeg
Man I just got it. My missing diode is on the bridge. I wanted to rectiy my HF with a diode in series with grenade because I wasn't using bridge. Now I see that this bridge makes the job.
URFA
Quote from: Jeg on November 11, 2014, 05:55:08 AM
Thanks a lot Urfa for your kind help. In your drawing I noticed two new things. A cap between grenade and ground, and a disconnected side at your bridge at the output. Is your bridge like that for purpose or you just forgot to draw the missing connection? In addition, is there any diode more between grenade line and ground?
You can connect other side of the bridge rectifier to the output. But this is not necessary. If you want to see the voltage you can connect other side to output as I drew.  "is there any diode more between grenade line and ground?" Jeg has given answer your question. Capacitor is actually a diode.
And you must connect plus or minus of the bridge to the other side of output. Not connect both to one side or not connect plus to one side and minus to other side.
URFA
Quote from: skywalker66 on November 11, 2014, 06:18:54 AM
I get it and thanks for trying !  ;)  And don't worry my english is the same, but that don't stop me to try in some degree to communicate.
What can tell about your kacer? What wire length do you use for it (or no. or turns) . Do you have a criteria in choising that length ? Do you had to modify your kacer in order to get the effect?
Regards !
Hi skywalker66.
skywalker66
Thanks Urfa, but I was referring at this setup  from your video.
Anyway never mind, please ignore my previous request.
Regards !
