0 Members and 188 Guests are viewing this topic.
URFA
Quote from: skywalker66 on November 11, 2014, 08:27:56 AM
Thanks Urfa, but I was referring at this setup  from your video.
Anyway never mind, please ignore my previous request.
Regards !
I gave information applies to for my setup. I just, I showed the picture to be understood. It values are valid for installation in the picture you sent.(my video)
Regards.
NickZ
  For the ground line to earth, seams like using a 100ohm resistor, a diode, or capacitor, may all be doing a similar purpose.  This all needs to be tested further.
  Urfa: Is that last picture of your grenade/kacher coils, of your current device ?
  If so, why don't you try to see if it will self run, now?  As that is the most important thing.
skywalker66
Quote from: URFA on November 11, 2014, 09:42:41 AM
Regards.
Thank you URFA ! I'll do the calculations.
URFA
Quote from: NickZ on November 11, 2014, 09:42:57 AM
Hi NickZ.
That is not picture of my current device.(Picture name:Kacher_parameter3) I found this picture on internet. I used it only write for information.
Really I don't have free time for try to see if it will self run. I am working on a Motion simulator and it takes all my time.But it will be finished in a short time.When my motion simulator is finished I will take the my all time to for Akula Device.
magpwr
Quote from: URFA on November 11, 2014, 04:00:11 AM
Hi magpwr
Answer to your questions.
1-I used 2.25 uf cap after 3 Turns.
2-I think it is not necessary connected to earth(To my way of thinking ) I don't any different effect when I connect it to ground.
Regards.
hi URFA,
If you mentioned 34.15khz in your circuit diagram for the PWM generator and the LC resonance of capacitor 2.25uf and 25 turns bifilar assume eg:124.5uH(For my case).
Which means if you get the chance to measure the frequency across capacitor it would be close to 9.5khz even though your pwm generator is 34.15khz only you get the resonance point right.
For my case it was 12.98khz for 1.2x uf capacitor even though my divide by 60 pwm generator was running at around 24khz."This windows to  see low frequency across capacitor is very narrow"
Regarding the choke to Kacher primary coil which you are using.
This is just a possible theory of mine and also one of my next upcoming plan-
I wonder if this choke is the one which one of the wire from the 3 turns is going through to create a moustache like signal which would also be present in kacher\tesla coil via primary coil.
I was using 30Amp 600volt diode 50ns recovery time to center tap to see this effect.
"But my kacher was weak and i was not using 2sc5200 yet at 19volts for the supply for all parts of circuit"
All work stop since Sunday due to possible component damage after applying 30volts to 7805 regulator which i got no time to inspect only until tomorrow.
