0 Members and 87 Guests are viewing this topic.
Jeg
Quote from: URFA on November 11, 2014, 07:36:43 AM
You can connect other side of the bridge rectifier to the output. But this is not necessary. If you want to see the voltage you can connect other side to output as I drew.  "is there any diode more between grenade line and ground?" Jeg has given answer your question. Capacitor is actually a diode.
And you must connect plus or minus of the bridge to the other side of output. Not connect both to one side or not connect plus to one side and minus to other side.
Urfa no words to thank you man.. ;)
Jeg
Hi Hoppy
You can also try to unwind some turns from your inductor like 24+24 or 25-23 and see the results. A good method is also to add few turns of a free end wire over your inductor. By giving some capacitance or inductance this way, you bring it where you want. But we have to admit that Ruslan's coils tuning is far from an easy job.
John.K1
Guys, re-viewing the schematics on the previous page,  it is not exactly what Ruslan said.  He was connecting the 6th end directly to the ground and the first end he put across the capacitor to the TV choke. The capacitor which suppose to be a diode - I thin that might be right.  There was some question about it but he answered very unclear . What we are very sure there must pulsate positive waves only. I will try to stick there some HV diodes from microwave.
I am just tuning my Tesla to the ground on the 6th end. All frequency drop down to :)  On the Emmiter of katcher I can see drop by 300KHz. I will try to put more wire now. If everything ok I should get my frequency back and the bulb should lit much stronger or even to burn.  And if not I think I will give a call to Ruslan in Riga :)  btw - my wife is Latvian and now in Riga :)
Jeg
Quote from: John.K1 on November 11, 2014, 01:21:46 PM
John, I suggest you not taking anything for granted! Ruslan changed his explanations many times. Anyway. The most appropriate connection of ground is at the thin side. HF have to reach ground from the shorter path which has the least resistance.
