0 Members and 86 Guests are viewing this topic.
John.K1
So what is going on here.
I have no light if ground is disconnected from Kacher's transistor's - emitter.
I just tried to connect one end f bulb to inductor coil (biffilar on grenade)  and together with ground it gives me more light.  Without ground it light less and takes more Amps 2.12A  with ground it gives more light and consumption drops to 1.88A  @ 24 V.
Not sure what to do. If to put much more wires and to watch brightness as taking turn by turn off the tesla?   Possibly the best way how to make sure the coil is properly tuned for your grounding?
Regarding to your cylinder antenna I have tried it already partially. I say partially as I wound Al foil around the copper turns.  My thinking was to get charge locked inside.   Not sure now what result I got. I think the frequency of kacher was allover the place jumping up and down.
Void
Quote from: John.K1 on November 11, 2014, 04:51:05 PM
Hi John. Not sure. My results are different than yours for some reason.
If I connect earth ground to one side of the grenade and to the
kacher driver supply negative, my kacher current consumption drops
quite a bit, but the output voltage on the tesla coil also drops quite a bit.
I get best results with my current circuit configuration with earth ground
to grenade but not to the kacher driver. Kacher is not affected by earth ground
much if earth ground is not connected to the grenade at the same time.
If you don't have anything at all connected to the grenade output wires, what is
the current consumption of your kacher driver?
All the best...
URFA
Hi to all.
I want to learn When you run your device, Does the your grenade coil and the inductor coil heats up?
In my setup, when I run my device 5-10 minutes later top of the grenade coil(12Turn area)is to be hot and 24turn area of the grenade coil is very little warming up.
And Indictor coil of the on grenade does not heat up When I touch.
If anyone try this, can anyone tell me that please?
magpwr
Quote from: URFA on November 11, 2014, 05:03:09 PM
Hi to all.
hi URFA,
For me it was the 25 turns bifilar winding on kapanadze winding 2.5 mm sq which was getting warm.
No heat detected using 4mm sq primary(12-0-12) and 28 turns 4 mm sq on my large nano-crystalline toroid.
For 3.5 turns on toroid i'm using 6 mm sq.
I am using "FGH50N6S2" 600volts 75Amp IGBT without internal diode version.No heat detect here as well just 8c more than my room temperature 30c.
The primary reason i stick with 600volts if let's say there is current if ever returning back from earth at the 3.5 turns.If 3.5 turns becomes primary from the returning current from earth i will need to ensure the voltage build up on 12 turns primary winding (which will become secondary step up along with 28 turns) don't
get blocked by the low voltage mosfet with internal blocking diode example 55volts.
It's my primary  reason before building why i choose to stick with 600volts IGBT just to be on the safe side.Snubber circuit provides the protection for IGBT.
John.K1
Are you sure you speaking about grenade coil??  it sounds to me more like you speak about TV choke (12 turns and 24 turns)
I didn't get there yet. I will connect that choke once I will get the basic tests done (bright lite when GND connected to grenade coil)   Just thinking about it, maybe I should improve my grounding. I have my 1/4" bar just at 30-40cm in ground :)
