0 Members and 575 Guests are viewing this topic.
Jeg
Like Magpwr my inductor is getting warmer than grenade itself.
Void I agree with the capacitive coupling and other ways for radiating. In fact, perhaps an aluminum foil plate would be more efficient.
John.K1
That capacitive coupling makes me mad :)  I just putted my home-made big capacitor  next to the antena and after some finger burn I got light on my bulb.  Once the light is going on so does consumption because that coupling- How to de-couple it??
btw- I got to light my bulb just by connecting one lead to the scredriver laying nearby :D
Jeg
Quote from: John.K1 on November 11, 2014, 04:09:51 PM
Hi Jeg.
Possibly you are right.  Let me to show you one of his older setup ups (4 month back)  which has been made by Ruslan himself and confirmed as working.  http://realstrannik.ru/forum/39-kapanadze/134930
John I will test it both ways to see if there is any difference.
About ground, is not an extension of grenade as you think. Capacitor and load interrupts the grenade line. In grenade's line you have to add the 28turns and the connection cables. When you know those lengths then consider about your frequency choice.
URFA
Quote from: magpwr on November 11, 2014, 05:25:37 PM
hi URFA,
For me it was the 25 turns bifilar winding on kapanadze winding 2.5 mm sq which was getting warm.
No heat detected using 4mm sq primary(12-0-12) and 28 turns 4 mm sq on my large nano-crystalline toroid.
For 3.5 turns on toroid i'm using 6 mm sq.
I am using "FGH50N6S2" 600volts 75Amp IGBT without internal diode version.No heat detect here as well just 8c more than my room temperature 30c.
The primary reason i stick with 600volts if let's say there is current if ever returning back from earth at the 3.5 turns.If 3.5 turns becomes primary from the returning current from earth i will need to ensure the voltage build up on 12 turns primary winding (which will become secondary step up along with 28 turns) don't
get blocked by the low voltage mosfet with internal blocking diode example 55volts.
It's my primary  reason before building why i choose to stick with 600volts IGBT just to be on the safe side.Snubber circuit provides the protection for IGBT.
Hi magpwr.
I think I could not express myself  :-[.  I drew on the picture(below) what I say.
By the way Your nano-crystalline toroid very nice, I like it  ;)
Thank you for your answer.
Best regards.
itsu
Quote from: Void on November 11, 2014, 04:10:58 PM
This is an initial test of putting a 15W light bulb across the grenade coil output leads and driving
only with the kacher driver................
Hi Void,
impressive, what bulb is it, 220V or 110V?
When using a 25W / 220V bulb on my Grenade (one side grounded), and the Kacher only activated on 24V@1A 1.5MHz, i have some 3mm streamer at the antenna, but no light in the bulb.
Probing the bulb shows a jagged like sine wave signal of only a few volts.
Did you probe across the bulb?  What signal do you have there?
How is your antenne wound compared to the bifilar coil (and 3/4 and 5/6 layer of the Grenade)?
No heating up noticed in the Greneade or bifilar coil here, the yoke gets an elevated temperature to the touch, but not much.
Regards Itsu
