0 Members and 460 Guests are viewing this topic.
skywalker66
Quote from: Void on November 11, 2014, 04:10:58 PM
This is an initial test of putting a 15W light bulb across the grenade coil output leads and driving
only with the kacher driver.
Well done Void !
I ask for few more detail about your experiment:
In your experriment do you have inductor in place over grenade and bifi ferrite bar between kacher and antena?
Do you try run kacher on bateries to avoid ground loop through power supply ?
Thank you !
skywalker66
Quote from: Void on November 11, 2014, 04:45:55 PM
Regarding what people are calling the 'antenna' winding, I believe that you can use a piece of aluminium
or copper foil in a cylinder shape over the 'inductor' winding and it may work just as well.
From my own testing, this 'antenna' winding is acting as a capacitive top load on the tesla coil
and its primary mode of radiation is via the electric field. So I think it is primarily passing
energy to the grenade coil though capacitive coupling (electric field), rather than through magnetic coupling.
If this is correct, and my own testing seems to confirm that it is primarily capacitive coupling to the
grenade coil (it works about the same with an aluminiun foil sheet in a cylinder shape as the radiator),
then it may not matter much at all in which direction the 'antenna' winding is made in. You may
get just as good results with an aluminium foil cylinder as the radiator. Since we don't know
what makes this device work however, you should probably stick to the way Akula and Ruslan did
it until you get over unity, then you can experiment as you like.  ;D
All the best...
Good guess ! It realy form a HV capacitor.
But your aluminum foil must not form closed loop ( a sort of short turn). It may work if a split is provided in aluminum foil, like in Akula first device or cibinidze device.
Regards.
Hoppy
Hi URFA,
I don't see the 10-12T and 50-60T toroid shown on your circuit schematic in your videos. I see a small TV ferrite yoke and this has two windings but with a different number of turns. Could you please give us some more detail on the ferrite chokes / transformers used in your device.
The performance of your device as shown in the videos looks closer to what we all should be aiming towards. Ruslan's video's show his lights illuminating without any pulsating or variance and this looks suspicious to me.
Void
Hi Itsu and Skywalker66.
Here are the answers to your questions.
The antenna winding for this initial test was just three turns of wire on a large cardboard cylinder form.
The antenna windings were wound in the same direction as layers 1 & 2 of the grenade coil.
The antenna was placed over layers 1 & 2 of the grenade coil.
I don't have the inductor winding in place for this test.  Once I am finished trying different tunings for max light
on the 15W bulb I will try the tests again with the inductor winding in place for comparison.
I did not have the ferrite bar with opposing windings between the tesla coil and antenna for this test.
I will try to compare results with it in place in later tests.
I was using a bench power supply set to 24V for this test. This was just an initial test but I will try with a battery
to eliminate any possible ground loops back to the power supply and see what the difference is.
Itsu, the 15W bulb I am using is rated for 120V, so that may possibly be why it lights and yours doesn't.
The voltage across the bulb is only about 3.4V peak, but it is lighting fairly brightly for that low of a voltage.
It may be a fairly efficient type of light bulb.
You may be able to get a 12V or 24V filament light bulb of some comparable low wattage to light instead if
your 220V light bulb does not light, but I tried a 12V 20W halogen bulb I had kicking around and it did not light at all.
Maybe a 10W or so 12V bulb might light.
All the best...
In the attached scope shot:
Yellow is the voltage waveform across the 15 watt bulb
Blue is a scope probe placed near the end of the tesla coil
